Wired and\or wireless backhaul help
davekstl
I have a GT-AX11000 as the main router, 2 ZenWifiAX's as nodes along with a RT-AX3000 as an additional node. I want to know if I can connect the RT-AX3000 as a wired backhaul and keep the Zen's as Wi-Fi. The RT-30000 is the furthest distance form the main router.
If I CAN do this, what do I have to change and to which devices?
Dave
Sure. Should autodetect the wired backhaul. If you have a switch in between make sure it is an unmanaged switch.
