P
proxort
Guest
After installing my new RT-N66U yesterday i spent an hour or so configuring it. Then after about 14 hours both the 2.4 Ghz and the 5 Ghz stopped working. Nothing in my network changed. All of the wired connections worked fine, there were no implications of anything going wrong in the router setup interface.
In desperation i tried three different firmwares from ASUS with factory resets and all that. After getting no where i contacted my retailer and got it RMA'd.
After getting the replacement i tried to reconfigure the router but with no luck. I have even tried the Merlin builds but with no luck, it's just between 5min and 10 hrs of working wi-fi before it cuts out again.
I have fiddled around with most of the settings, and done some extensive googling but with no luck.
