Wireless disables after a few days (RT-AC88U/386.7)
maxcolla
Greetings,
my router works well until it disables the wiress radio alltogether. Note that there is no schedule set and I nornally have to reactivate it through the professional tab under the wireless menu. I never had this problem with the native firmware. Can anyone shed some light? Thanks. Max
Check temperature. Sometimes the thermal paste is not correctly applied and the module switches off if it overheats.
even after replacing the thermal paste or thermopad, the temperature can drop by 10 degrees celsius.
