takeawaydave
Hi been encountering a problem where my laptop as well as desktop start to not be able to access the network and rebooting my rt-ac66u (with 3.0.0.4.372.30_2) appears to solve the problem. Not sure what its related to nor how to proceed in narrowing down the problem.
symptoms are varying:
1. sometimes a ping to router is possible - other time no route to host.
2. ssh router on to router mostly doesn't work when it does its slow and a slow sesssion ensues.
3. a nslookup to external website e.g. nslookup google may resolve some times not.
I don't see packet errors on the local adapter. and the wireless signal has max bars (not bad reception). Using the 2.4 Ghz network.
I suspect this is the start up log not the one capturing any problem but a guru eye may spot something
http://pastebin.com/embed_js.php?i=EXCpG8xE
Recently set dnsmasq up not sure if this is to blame.
Thanks for looking and any advice on troubleshooting appreciated.
