Wireless Log accuracy on .260 build
cdbma
I'm running 260 firmware and I'm using the wireless log to learn about the router, speeds, impact of tuning, etc. However, it seems that the log is not always accurate. It does not appear to list all active wireless clients and I frequently see what appears to be bogus information. For instance, right now, there's an entry under the "11n" setion that has a MAC of all zeros (I often see other bogus MAC addresses), a PHY mode of "CCK" (isn't that 11b?) and a Rate of "1M." I often see bogus rate and connect times, as if the register has overflowed (ie. huge values that make no sense). Also, I currently have two iPads connected to the router, but I only see one. Finally, doing a refresh will often just list new bogus data. I just did a refresh and the MAC is still all zeros, but the PHY Mode is now "Green", but the Rate is "-25396615M." The time is also a huge bogus number.
Anyone else seeing this? I'd go to Padavan's firmware if this feature, and others, work more reliably.
