Wireless not connecting? Is it due to Windows upgrade?
Steve40th
I had to put a new hardrive in laptop, went from Windows 7 to Windows latest 10 version. I have a 7260AC wireless card in here with drivers 17.15.0.5. I have problems connecting, and today it just wont connect with Hotel at all?
Will newer drivers help, or am I needing something else?
Thnx
have you tried another place with wireless - maybe a coffee shop ?
Does it connect to the AP there ?
can you see any ssids ? Maybe neighboring rooms ?
does the lan port work correctly ?
was this a conversion of win7 or a bare metal install of win10 ?
What version of win10 ?
depending on the answers it might not be the laptop os.
that being said, there was a w10 version upgrade issue that lost the networking and i think required a registry edit to fix. That was a while ago though so if you are running current release, maybe not a concern.
Try updating drivers and see if it helps, my tenant once had issue where it would stop seeing ssid on ax based router updating driver fixed it.
