Wireless Radios Issue with New RT-N66U
zell045
I'm having trouble with the wireless radios on my new router. They just seem to get disabled (can't connect and the lights are off) randomly after a few hours of uptime, requiring a power cycle to get working again. I have the latest .260 firmware and there is nothing odd in the syslog.
Any help would be appreciated.
Make sure you didn't accidentally establish a radio schedule (Wireless -> Professional tab).
Otherwise, check the System Log page to see any indication as to what could be happening.
Might also be worth resetting back to factory defaults and reconfiguring your router in case you might have some corrupted settings in nvram (especially if you have been upgrading the FW over multiple versions or from a much older version).
The radio schedule settings are at the default configuration.
I upgraded from .220, but I'll try to reset the nvram when I get back from work.
Thanks.
B Issue with wired clients on ASUS N56U ASUS N Routers & Adapters 0
