im looking for a router for wired only. would any of you recommend your wireless router, even if i choose to turn off the wireless? my home network will be using superior essex cat6a.
sem- already looked into this option. The industry is concentrating on consumer wireless routers. non consumer units are rated quite low. apparently they have very poor integrated software and zero tech support. I want a well tested unit.There are wired only routers, just look into the non consumer stuff and also with x86.
Depends on what your budget is. A (more) general purpose device is always more useful for longer than a (more) single purpose device is.
Unless you have extreme demands (QoS, reporting, etc.) even an RT-N56U would serve you well instead of an wired-0nly router. Though I would still suggest the RT-AC56U for overall bang for the buck (even for just 'wired routing mode').
I dont think the ones sold for businesses and more are untested. Tech support really depends. For example mikrotik license level 6 comes with 1 month of support. pfsense is actually very easy to configure and use and you can recycle hardware to run it on. A lot of products that come from suppliers like ubiquiti, mikrotik and so on come with support from the suppliers. Support for non consumer devices are actually more than consumer devices and these devices are tested more vigorously than consumer hardware and put through all sorts of stress. Some of these devices are even cheaper than ASUS and have much better QoS.sem- already looked into this option. The industry is concentrating on consumer wireless routers. non consumer units are rated quite low. apparently they have very poor integrated software and zero tech support. I want a well tested unit.
ok. i read a number of ubiquiti wired router reviews on amazon. the ubiquiti router (amazon) reviews are almost all negative. users report very challenging setups with ubiquiti routers. i want a well tested router which is discussed on these forums, with a consumer friendly setup.A lot of products that come from suppliers like ubiquiti, mikrotik... Some of these devices cheaper than ASUS and have much better QoS..
thats because such routers require skill to configure. I would treat the edgerouter as a linux server as the GUI doesnt help much in configuring it. netduma is a gaming orientated router that uses mikrotik hardware but with their own user friendly interface.ok. i read a number of ubiquiti wired router reviews on amazon. the ubiquiti router (amazon) reviews are almost all negative. users report very challenging setups with ubiquiti routers. i want a well tested router which is discussed on these forums, with a consumer friendly setup.
" By far the weakest point of the Netduma hardware is the wifi. It only has 802.11 b/g/n support on the 2.4 GHz channel. Almost all commercially available N routers today include the 2.4 and 5 Ghz wifi channels." Thus, your 2 options are a bust. i need a consumer friendly router that does not require advanced networking skills.thats because such routers require skill to configure. netduma is a gaming orientated router that uses mikrotik hardware...
anybody using the apple airport extreme router, 6th version? it has 802.11ac . it seems to have good reviews.
You do contradict yourself as you said you wanted a wired router. There are routers like the cisco rv (but not the cisco rv itself which i dont recommend) that have user friendliness and better quality. Even pfsense isnt difficult to configure with its GUI and x86 is a lot faster." By far the weakest point of the Netduma hardware is the wifi. It only has 802.11 b/g/n support on the 2.4 GHz channel. Almost all commercially available N routers today include the 2.4 and 5 Ghz wifi channels." Thus, your 2 options are a bust. i need a consumer friendly router that does not require advanced networking skills.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
