wireless scheduler issue
tommy1
hi,
i have RT-AC66U_B1 with merlin firmware for RT-AC68U as official guidlines claim
when i turn on wifi scheduler on wireless -> professional for 2,4 or 5 Ghz setting, click ok and then when I come back to that settings its set back to "No"
i have firmware Version:384.16, but with 384.15 it was the same.
any hint ?
thanks
When you flashed RMerlin firmware originally, did you do a full reset/Initialize all settings and then manually and minimally configure the router to connect to your ISP and secure it?
If you did, how many firmware versions ago was that? It may need to be done again to get the router back to a good/known state.
See if anyone answers in the next 24Hrs or so, but if there is no answer with a resolution, then a reset is indicated.
frankly speaking I dont remember exactly, but after I bought the asus router, then right after I updated the original firmware with merlin, like a regular update, without any reset to factory defaults settings,
then did some config with security, vpn etc and then this merlin software I have updated recently with newer version, but wifi scheduler didnt work with my first merlin firmware version and current one (384.16)
do you think there's other router setting that influence wifi scheduler I should have a look at ?
With over 100 views on this thread and no other replies, I would guess that an M&M Config and possibly/ideally a Nuclear Reset would be your best bet to get this working as it should.
Depending on the firmware originally installed and the RMerlin firmware you flashed initially, the issues/gremlins could be there since then.
You may want to wait for further input, but you could have a completely 'new' and fresh network in less than an hour. :)
The following is what you can find in the link in my signature.
HTH. :)
amtm Step-by-Step https://www.snbforums.com/threads/amtm-step-by-step-install-guide-l-ld.56237/#post-483421
M&M Config https://www.snbforums.com/threads/n...l-and-manual-configuration.27115/#post-205573
Sanitize Network https://www.snbforums.com/threads/rt-ac66u-slow-wan-to-lan.12973/page-3#post-269410
Save NVRAM Settings https://www.snbforums.com/threads/asus-dsl-88u-transfer-settings-question.42274/#post-359390
Control Channel Set up https://www.snbforums.com/threads/a...details-in-the-description.55582/#post-472051
RT-AC3100 Report https://www.snbforums.com/threads/s...-go-with-the-rt-ac1900p-v3.34748/#post-281391
Are you safe with VPN https://www.snbforums.com/threads/to-vpn-or-not-to-vpn.55600/page-2#post-472951
WPS NVRAM Erase https://www.snbforums.com/threads/b...eta-is-now-available.55520/page-9#post-473141
MU-MIMO Setting https://www.snbforums.com/threads/asus-rt-ax88u-experiences-discussion.49427/page-14#post-473643
Nuclear Reset https://www.snbforums.com/threads/major-issues-w-rt-ac86u.56342/page-4#post-495710
RT-AX88U Upgrade https://www.snbforums.com/threads/b...ta-is-now-available.60037/page-31#post-531024
Why a new SSID? https://www.snbforums.com/threads/i...-ax88u-rt-ac86u-node.60551/page-2#post-532915
Rebooting Ways https://www.snbforums.com/threads/rebootin-router-with-usb.61513/#post-545685
Unbound Report: https://www.snbforums.com/threads/u...-caching-dns-server.58967/page-53#post-547399
