Wireless is set to 300Mbps but laptops only get 150Mbps.
Because my router don't has wireless, i have bought a TP-Link TL-WA830RE to be my access point in order to have wireless at home.
But after all is setup and configurated on the access point to 300Mbps, when looking at both my laptops wireless network speed its says 150Mbps. Both the laptops are Asus K55VM and are located just 3 metters away from the access point.
So my question is why don't i get on the laptops 300Mbps speed?
Its some setting that i must change on the access point or the problem is from my laptops that don't support 300Mbps?
Any advice its very appreciate. I really need help on this problem.
Bellow i leave you the main wireless settings defined on the access point:
Channel: 1
Mode: Only N
Channel With: 40Mhz
Max Tx Rate: 300Mbps
Channel: 1
Mode: Only N
Channel With: 40Mhz
