Hello... I'm a newbie, so hopefully people won't bash...
Background:
I live in a medium density residential area. Just bought the router yesterday and upgraded firmware to .246. Have about 10 wireless networks in my neighborhood scanned using NetSurveyor utility. I've set the channel at 7 or 8 (where no other network is using)
- when router plugged into laptop, I get ~20mbps down, ~0.5mbps up from speedtest.net (ping is less than 20ms)
- when using wifi (2.4ghz) with laptop, I get ~6mbps down, ~0.5mbps up from speedtest.net (ping is less than 20ms); laptop next to router
- when using wifi (2.4ghz) with iphone4, I get ~3-9mbps down, ~0.5mbps up from speedtest.net (ping is 80-100ms); iphone4 next to router
Are these wireless speeds typical? I get these wireless speeds with my predecessor router (WRT54GL), and thinking of reading the raving reviews for the RT-N66U, I was hoping speeds would drastically improve (at least to 15mpbs down).
I can't even stream a 720p video without waiting it to load completely... has this to do with the firmware upgrade? I've rebooted & reset the router (holding the button for 30 sec on the router) after firmware upgrade.
Things to note:
- 5ghz band (no device can run this frequency)
- everything can run on 'n' if possible, otherwise can consider to run on 'g'
Do I need to reside to using tomato? (I've had tomato installed in my WL-520GU before, so I am familiar with the process)
Thanks in advance!
Background:
Things to note:
Thanks in advance!
