Wireless Wrong
Shonk
Something i noticed today
If i set my 2.4ghz to channel 13 extension channel below in the firmware it says its at 40 Mhz
but in reality it sits using 20 Mhz of spectrum
To fix it i have to set it to channel 9 with extension channel above
which results in channel 9 + 13
It seems to affect the upper end of the spectrum on 2.4ghz
Both my AC88U and my AC66U do this
On Both Stock Firmware and Merlin
It seems to me that channel 12+13 arnt setup properly
and in some cases the firmware will make a choice that it would make on a 1-11 device
instead of a 1-13 device
my AC88U also does exactly the same
so its a longstanding issue in the 2.4ghz band for eu users
i suspect its present on all eu asus broadcom based routers
9 Above works as expected
All the above was the AC66U
Here's the AC88U doing exactly the same
just to confirm
Im shocked nobody has ever noticed this bug
13 Below doesnt work as expected
http://s5.postimg.org/efofu2xqv/13_Below.jpg
12 Below doesnt work as expected
http://s5.postimg.org/u2fp7gbiv/12_Below.jpg
http://s5.postimg.org/5n7h6eclz/9_Above.jpg
8 Above works as expected
http://s5.postimg.org/4tuvds6l3/8_Above.jpg
It's also possible the wireless scanner(inSSIDer) you are using does not recognize channels correctly beyond 11. Try another scanner that is written specific to EU channeling.
You nailed it on the head
Just wired up an old TP-Link TL-WR1043ND v1
and it was exactly the same with inssider on 12 and 13
