sfx2000
Part of the Furniture
Packet geeks might want to update...
Bug Fixes
The following vulnerabilities have been fixed:
AFS, ANSI IS-637 A, BACapp, BT BNEP, Cisco FabricPath MiM, CSN.1, DCERPC SPOOLS, DIS, Ethernet, GSM A RR, ICMPv6, IEEE 802.11, IPv4, ISUP, J1939, JXTA, LAPSat, LPADm, LTE-RRC, MRCPv2, NFS, OpenFlow, SGsAP, SMB, STT, TZSP, UMTS FP, and USB
New and Updated Capture File Support
Aethra, Catapult DCT2000, CoSine, DBS Etherwatch, ERF, iSeries, Ixia IxVeriWave, NetScreen, Toshiba, and VMS TCPIPtrace
Bug Fixes
- wnpa-sec-2016-29
The SPOOLS dissector could go into an infinite loop. Discovered by the CESG.
- wnpa-sec-2016-30
The IEEE 802.11 dissector could crash. (Bug 11585)
- wnpa-sec-2016-31
The IEEE 802.11 dissector could crash. Discovered by Mateusz Jurczyk. (Bug 12175)
- wnpa-sec-2016-32
The UMTS FP dissector could crash. (Bug 12191)
- wnpa-sec-2016-33
Some USB dissectors could crash. Discovered by Mateusz Jurczyk. (Bug 12356)
- wnpa-sec-2016-34
The Toshiba file parser could crash. Discovered by iDefense Labs. (Bug 12394)
- wnpa-sec-2016-35
The CoSine file parser could crash. Discovered by iDefense Labs. (Bug 12395)
- wnpa-sec-2016-36
The NetScreen file parser could crash. Discovered by iDefense Labs. (Bug 12396)
- wnpa-sec-2016-37
The Ethernet dissector could crash. (Bug 12440)
- Saving pcap capture file with ERF encapsulation creates an invalid pcap file. (Bug 3606)
- Questionable calling of Ethernet dissector by encapsulating protocol dissectors. (Bug 9933)
- Wireshark 1.12.0 does not dissect HTTP correctly. (Bug 10335)
- Don’t copy details of hidden columns. (Bug 11788)
- RTP audio player crashes. (Bug 12166)
- Crash when saving RTP audio Telephony→RTP→RTP Streams→Analyze→Save→Audio. (Bug 12211)
- Edit - preferences - add column field not showing dropdown for choices. (Bug 12321)
- Using _ws.expert in a filter can cause a crash. (Bug 12335)
- Crash in SCCP dissector UAT (Qt UI only). (Bug 12364)
- J1939 frame without data = malformed packet ? (Bug 12366)
- The stream number in tshark’s "-z follow,tcp,<stream number>" option is 0-origin rather than 1-origin. (Bug 12383)
- IP Header Length display filter should show calculated value. (Bug 12387)
- Multiple file radio buttons should be check boxes. (Bug 12388)
- Wrong check for getaddrinfo and gethostbyname on Solaris 11. (Bug 12391)
- ICMPv6 dissector doesn’t respect actual packet length. (Bug 12400)
- Format DIS header timestamp mm:ss.nnnnnn. (Bug 12402)
- RTP Stream Analysis can no longer be sorted in 2.0.3. (Bug 12405)
- RTP Stream Analysis fails to complete in 2.0.3 when packets are sliced. (Bug 12406)
- Network-Layer Name Resolution uses first 32-bits of IPv6 DNS address as IPv4 address in some circumstances. (Bug 12412)
- BACnet decoder incorrectly flags a valid APDU as a "Malformed Packet". (Bug 12422)
- Valid ISUP messages marked with warnings. (Bug 12423)
- Profile command line switch "-C" not working in Qt interface. (Bug 12425)
- MRCPv2: info column not showing info correctly. (Bug 12426)
- Diameter: Experimental result code 5142. (Bug 12428)
- Tshark crashes when analyzing RTP due to pointer being freed not allocated. (Bug 12430)
- NFS: missing information in getattr for supported exclusive create attributes. (Bug 12435)
- Ethernet type field with a value of 9100 is shown as "Unknown". (Bug 12441)
- Documentation does not include support for Windows Server 2012 R2. (Bug 12455)
- Column preferences ruined too easily. (Bug 12465)
- SMB Open andX extended response decoded incorrectly. (Bug 12472)
- SMB NtCreate andX with extended response sometimes incorrect. (Bug 12473)
- Viewing NFSv3 Data, checking SRTs doesn’t work. (Bug 12478)
- Make wireshark with Qt enabled buildable on ARM. (Bug 12483)
