WL-330NUL (802.11n pocket router) - potential security issue
sfx2000
Part of the Furniture
Interesting.. and with current FW there's no way to disable it - 3.0.0.35
http://router.asus.com/Main_AdmStatus_Content.asp
Let's you bypass the admin login screen and enable telnetd from the WLAN side...
See attached...
Wonder if this is present on other ASUS routers
sfx
How are you so sure you did access that page from the WAN side?
Did you go over to your neighbors, using their Internet connection, their computer and tried to open the given URL?
The given URL usually works (only for certain Asus devices) only from the LAN side of the router and should ask for the router login credentials.
[EDIT] Sorry, misread, you wrote WLAN (Wireless LAN), not WAN (Wide Area Network, in this case the Internet).
Still, the page should ask your credentials.
Clear your browser cache, close and restart the browser and try to access the page again.
it was from the WLAN side - still a serious security issue with cross-site attacks...
My main concern here though - other devices, do they have the same issue?
Well I still like to see your confirmation that you can really access that page without the router ever asked your credentials:
Clear your browser cache, make sure cookies are removed as well, close and restart the browser and try to access the page again.
Does it ask Username and Password now?
My RT-N66U has the same page and the router for sure asks credentials first. Once you are logged in to the router and open the page, it does not ask for credentials again.
Cross Site Attacks would be that the configuration page in the router has malicious code to redirect you to some other page instead of your router configuration.
Checked that before I posted - was thinking the same thing myself - that URL doesn't validate the user - so basically from the WLAN side of the device, there isn't any security..
this is exactly how issues like this become problems - it doesn't need to be local...
This is another issue - but also with this device, depending on the mode it is in, the admin page isn't always on http://192.168.1.1
the www.asusnetwork. net URL is also scary - this is not an official ASUS URL - takes you to a "support" site of sorts, but it ain't ASUS...
ASUS did fix that in the 3.0.35 firmware release for that device - to get to the admin page - router.asus.com - but that doesn't really fix anything does it?
