WNDR4500v2 Losing SSID
greywolfe
New, couple of weeks old, Netgear WNDR4500v2 just start losing the 2.4GHz SSID.
2.4GHz Wireless Devices (Wireless intruders also show up here)
SSID	IP Address	MAC Address	Device Name
--	--	28:92:4A:BE:50:F2	--
This happened for the first time yesterday evening. At that point I rebooted the router from the web interface. Now tonight, same thing. At this point I am the only wireless user on the network. Naturally switched to 5GHz and that is working fine.
As can be seen in the code box above, my 2.4GHz ssid has disappeared. Not sure how to proceed with trouble shooting. Rebooting router all the time is not an acceptable option.
FYI, running the following firmware version,V1.0.0.54_1.0.33
Update:
Went into settings for the 2.4GHz frequency and changed the channel setting from 'Auto' to a specific channel, in the case, 11. Things seem to be working fine now. At least for the time being.
Could have been a quirk where when you initially set it up it didnt properly write the SSID to its internal memory. Switching the channel may have caused it to rewrite its data. If you still have this issue exchange the router. Its defective.
Bob Silver
Netgear
Bob Silver
Netgear
Thanks bobsilver for the reply.
Will see how things go. Hopefully, no more problems.
