WOL Tab interface?
rung
I usually use a script to wake up my PC, but just now l needed to use the WOL tab in the UI and found it doesn't seem to work for me anymore. I investigated and found that my script uses the interface option "-i br0" when calling ether-wake. When I try to use this command without this parameter, it also doesn't wake my PC. Is there any chance to request an option to select the interface on this page in the future? Or is my issue somewhere else?
Thanks,
Rung
I'm pretty sure the command invoked by the WOL tab always contains the -i br0 parameter. What makes you think otherwise?
It was a guess since the UI didn't work at all and when I tried from the command line, the command works fine unless I removed that parameter. I also don't use the "-b" in my script. Could that be maybe why the UI isn't working for me?
The router uses ether-wake -i br0 -b followed by the MAC address. So it only works on the main LAN (br0), not isolated guest networks or other VLANs.
