d5aqoep
This bug has been irritating me for so long. It has been discussed on AsusWRT-Merlin section as well. However, I feel this is AsusWRT bug.
A workaround for missing clients has been found:
Enable a guest network on 2.4 Ghz
Hide SSID: Yes (So that you won't be bothered by it.
Set network password (for obvious security)
Access Intranet : Disabled
Keep rest of the things on default.
Now each and every device on your LAN will magically appear. If you run into some random odd issues, let me know.
Credits to Dave. His reply at the end of thread here:
superuser.com
Why do some devices not show up in the connected clients list on my Asus RT-AC68U router?
I have two other routers (RT-AC57U) connected to my main router via 30m ethernet cables, and set up as access points. Everything works perfectly - I can connect via wifi to any of the routers, and
