WPA2-Personal vs WPA2/WPA3 Personal
neil0311
Been searching and trying to find clarity around those two network security settings. I have mostly modern devices with OS's that support WPA3, but some older devices and IOT devices that may/do not. Does the WPA2/WPA3 Personal in the Asuswrt wireless settings provide WPA3 for devices that support and fallback to WPA2 for devices that don't? Is that how that setting is intended?
Hawk
Correct, when you select wpa2/wpa3. Devices which support wpa3 will use it and rest will use wpa2 for their encryption.
neil0311
Is it worth using it in practicality, or just stick with WPA2-Personal? Any known issues associated with WPA3/WPA2?
L&LD
Part of the Furniture
Yes, lots of known issues. Depending on your client mix, router, firmware version, etc. WPA3 isn't prime time yet (for all).
The best results (i.e. no issues related to these settings) are all on WPA2 or all on WPA3. The mix is the nix. ;)
Not hard to test though if all your devices can use WPA3 or not.
Or, WPA2/WPA3, as required by the client device.
But what I would not spend a second on is trying to 'fix' why it works or not (just use tried and true WPA2 at that point).
