WPS Button change function ??
HorstG
Hello, I have a RT-N66U with Merlin ... 32
I used no WPS.
Is it possible with the WPS button the guest WLAN switch on?
I have to restart the PC and then start the guest WLAN via a web interface.
This is very cumbersome.
This text I translated with Google.
THX Horst
Not possible.
@2017... still no way to run a custom script when the WPS button is pressed ?
You're welcome to write the necessary code, test it, and provide a pull request if this feature is THAT important to you, and you think it's really a 5 minutes job to implement it.
