Unbound Wrong installation path
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
rlj2
Unbound install through amtm sets the path in service-event to /jffs/scripts/unbound_stats.sh , the correct path is /jffs/addons/unbound/unbound_stats.sh .
Noticed this through many resets.
Martineau
Part of the Furniture
Are you on the latest version.....what does the following show?
find /jffs/ -name "unbound_stats.sh" -type f -exec grep -F 'SCRIPT_VERSION=' {} +
rlj2
readonly SCRIPT_VERSION="v1.3.0" << shows this from your command.
shows in amtm
7 open unbound Manager v3.21
Installing through amtm. Ive done a crapload of different firmwares, factory resets lately. Ive had to change path everytime.
Heres another version it shows.
unbound (pid 3437) is running... uptime: 0 Days, 04:30:59 version: 1.12.0 # Version=v1.11 Martineau update (Date Loaded by unbound_manager Sat Jan 16 05:45:57 EST 2021)
Martineau
shows in amtm
The entry in service-event is managed by unbound_stats.sh and its install path variable should be revealed by
find /jffs/ -name "unbound_stats.sh" -type f -exec grep -E 'SCRIPT_VERSION=|SCRIPT_DIR=' {} +
You could manually remove unbound_stats.sh from service-event and trace the sh -x /jffs/addons/unbound/unbound_stats.sh install command
rlj2
Under Autoservice in your script, it only puts the correct path IF service-event is already present. On a new install it is not.
service-event after running unbound_stats.sh install twice
#!/bin/sh
/jffs/scripts/unbound_stats.sh generate "$1" "$2" & # Unbound_Stats.sh
/jffs/addons/unbound/unbound_stats.sh generate "$1" "$2" & # Unbound_Stats.sh
Martineau
#!/bin/sh
FYI unbound_stats.sh is not my script....my unbound_manager.sh script simply downloads it from @juched's Github.
