WRT610-N Emule issue
nalooti
anyone has been experiencing a lowID and/or KAD in a Firewalled state?
Since I put my router in place between the PC and the modem, I got Low ID on emule (edonkey p2p).
I've upgraded to the 1.00.03.15 version of July 2009, disabled UPnP, and opened the required ports on my WRT610-N router for emule to listen to incoming connections but still have a LowID/KadFirewalled state on emule. I also disabled SPI feature in security tab with no change.
I wonder why those ports that should be opened seems not open (I suspect that because of the state of emule) ?
What is interesting is that I got this state just after I setup the router so that it sits between my modem and the PC.
Before I had no problem With my PC directly connected to my old modem/router. It works as a router and modem and the WRT610-N as a second router both creating two subnets in my home network. Between the two routers I have IP/Ethernet and after the modem toward Internet I have PPPoA. I mean, if I unplung the router and connect the PC again to the old router/modem, it works without changing anything on the old router. Which suggests that the problem comes from the WRT610-N.
I have opened a port on TCP and UDP on the old router toward the IP @ of my WRT. I have also opened the same port on TCP and UDP on WRT toward my PC. Do you think that port forwarding can't be done both traversing two routers doing NAT ?
Funny is that in the last release note (less than 2 weeks ago), I see few port forwarding issues "resolved".
What is Home Network Defender? WRT seems to have problems with that! How is it possible to disable it?
Thanks for any help
nalooti
Double-NAT is tricky to handle well. Is there a compelling reason you need the modem to be a router? If not, you can set the modem to bridge mode and use the router itself for routing. This will result in only one subnet in your network and make everything easier.
I completely agree with you. Problem is I tried this in the first place and I couldn't get it run, the WRT, configured to initiate a PPPoE tunnel to my ISP (throughout the modem in bridge mode), telling me that the PPPoE server doesn't give it an IP address!
So I configured the WRT in plain IP with DHCP client asking the modem (now working also as a router) to give it an IP address which is private.
I'd really like to discuss with you if you have configured a modem in bridge mode and the router behind building the PPP connection to the ISP.
In the meantime, i agree that double NAT is tricky and anyway I wonder if I should not allow anything , any port to pass throughout my second new router since the first one (doing PPP with the ISP) which is configured as a router blocks all other ports already!
thanks
nalooti
