Xbox Local Cache Full
Martin_D
So for the last couple of weeks I keep getting a warning that my local xbox cache is full. So it looks like a ip is being blocked but for the life of me I can't track it down on the network
Asus RT-AC5300 | Asuswrt-Merlin 384.5
AB-Solution v3.11.2 | Skynet v6.1.6
DNScrypt-proxy 2.0.12|
I’ve never seen that before, but seeing your stuff, make sure you’re not blocking Microsoft servers (windows telemetry, etc) in AB/Skynet. That will mess with achievement stuff.
power cycle your xbox, I had that two power it down with the button till the light is off, wait at least 30 seconds before you power the xbox back on also make sure to unplug the power cable at the back, and press the power button a few times to make sure its drained.
Nope still having this problem
It's the instructions on the xbox website, and that's what fixed it for me, also which xbox model s or x or original?
Xbox one X
My network set up
AB-Solution - shooter40sw+
DNScrypt set up -
cert_ignore_timestamp = true
server_names = ['cisco', 'cisco-familyshield']
listen_addresses = ['127.0.0.1:65053']
## Maximum client connections to accept
max_clients = 250
# Use servers reachable over IPv4
ipv4_servers = true
# Use servers reachable over IPv6
ipv6_servers = false
# Use servers implementing the DNSCrypt protocol
dnscrypt_servers = true
# Use servers implementing the DNS-over-HTTPS protocol
doh_servers = true
# Server must support DNS security extensions (DNSSEC)
require_dnssec = false
# Server must not log user queries (declarative)
require_nolog = false
# Server must not enforce its own blacklist
require_nofilter = false
## Always use TCP to connect to upstream servers
force_tcp = false
## DNS query response, in milliseconds
timeout = 2500
## Keepalive: (HTTPS, HTTP/2) queries, in seconds
keepalive = 30
## Load-balancing
lb_strategy = 'p2'
## Log level
log_level = 2
## log file for the application
log_file = 'dnscrypt-proxy.log'
## Use the system logger
use_syslog = true
## Delay, in minutes, after which certificates are reloaded
cert_refresh_delay = 240
## DNSCrypt: Ephemeral_keys
 dnscrypt_ephemeral_keys = true
## DoH: Disable TLS session tickets
 tls_disable_session_tickets = true
## DoH: specific cipher suite
 tls_cipher_suite = [52392, 49199]
## Fallback resolver
fallback_resolver = '194.168.8.100:53'
ignore_system_dns = true
## Automatic log files rotation
# Maximum log files size in MB
log_files_max_size = 10
# How long to keep backup files, in days
log_files_max_age = 5
# Maximum log files backups to keep
log_files_max_backups = 1
## Filters
block_ipv6 = true
## DNS cache
cache = true
## Cache size
cache_size = 512
## Minimum TTL for cached entries
cache_min_ttl = 600
## Maximum TTL for cached entries
cache_max_ttl = 86400
## Minimum TTL for negatively cached entries
cache_neg_min_ttl = 60
## Maximum TTL for negatively cached entries
cache_neg_max_ttl = 600
[sources]
  [sources.'public-resolvers']
  urls = ['https://raw.githubusercontent.com/DNSCrypt/dnscrypt-resolvers/master/v2/public-resolvers.md', 'https://download.dnscrypt.info/resolvers-list/v2/public-resolvers.md']
  cache_file = 'public-resolvers.md'
  minisign_key = 'RWQf6LRCGA9i53mlYecO4IzT51TGPpvWucNSCh1CBM0QTaLn73Y7GFO3'
  refresh_delay = 72
  prefix = ''
Xbox Port Forwarding - Port 49469 Protocol BOTH
If you haven't whitelisted microsoft.com domains, that block list will be interfering.
Thank you looks like you are correct So I have just unblock about 110+ domains is that ok
Update achievements are now unlocking
Update 2 Nope dnscrypt-proxy just completely broken down as soon as I add the domains to ab-solution ?
account-microsoft.com
 accounts-microsoft.com
 advertising.microsoft.com
 amer.hops.glbdns.microsoft.com
 apprep.smartscreen.microsoft.com
 c.microsoft.com
 c1.microsoft.com
 choice.microsoft.com
 corpext.msitadfs.glbdns2.microsoft.com
 df.telemetry.microsoft.com
 error-code-0x800f0906-microsoft.com
 gmicrosoft.com
 in-pdf-microsoft.com
 isedocumentsonmicrosoft.com
 logimicrosoft.com
 mcpmicrosoft.com
 microsoft.com-0003.info
 microsoft.com-firewall-0xcb1982.info
 microsoft.com-firewall-i6j.info
 microsoft.com-msoft52.info
 microsoft.com.org
 microsoft.com.zeceftpf7i1m2fxypwmtgw.stream
 notice-securitybulletin-microsoft.com
 oca.telemetry.microsoft.com
 redir.metaservices.microsoft.com
 reports.wes.df.telemetry.microsoft.com
 safety.microsoft.com.agrosxd.lf6jzyfv6ngauly.stream
 safety.microsoft.com.alhyhsc.v58xwkqryxp3yxwsss4k.science
 safety.microsoft.com.aodgepfuau.lmicmpzeo3t.stream
 safety.microsoft.com.bcgql.oeuz51qquxi1lzcf9w.bid
 safety.microsoft.com.bgbzjk.eg6akswziho.science
 safety.microsoft.com.bgnmxey.pj2zlkshfi1f.review
 safety.microsoft.com.biaxm.31mhacrbhdws7urkua.review
 safety.microsoft.com.bjjsaajd.p03szzqsr053w.download
 safety.microsoft.com.blgftpdj.nvu7i2iobhlsdgznsq.trade
 safety.microsoft.com.bmmmubsox.ahay9tno6rvnpfwlmk22.bid
 safety.microsoft.com.btbqw.eddsgqhfe8sbng8niofb6zkpq.download
 safety.microsoft.com.bvschidtf.svldiufp2mmktyh1noa.review
 safety.microsoft.com.chvbfyuxwdy.kvjjhr9f5uh6ig.stream
 safety.microsoft.com.cifmutakhg.kcg62ud21gzwpm6kba.download
 safety.microsoft.com.cnowx.jwtuwitv1xx.review
 safety.microsoft.com.cvnsb.lcsg2xcbvcybq.review
 safety.microsoft.com.dqmeajscq.erh0dnydhamf.download
 safety.microsoft.com.dskbzbhbbg.buxgw5uwcxfavk28.trade
 safety.microsoft.com.eibllfyuq.4dr2orjw0p1mqvdolq7i.trade
 safety.microsoft.com.eqbrtrb.tias2wxk59u9lgarwk0.bid
 safety.microsoft.com.eynltiyzhft.siztmelleuhm8olbyw.bid
 safety.microsoft.com.ezkfoc.hkojkf9maszm1futehlulrl.science
 safety.microsoft.com.fimgsvhpb.kckjxkbuktd4va0zkp5kt8qm.download
 safety.microsoft.com.gnzvdmjtls.kxdkenpolf.download
 safety.microsoft.com.gqogzha.we8aoybem2f9seurk5bensatcs.stream
 safety.microsoft.com.hcpes.r7whxgsf77pzw.science
 safety.microsoft.com.hdtcsxsjzit.bj9p7f2xm7qgqm8hnyi0.review
 safety.microsoft.com.hepnwj.ebtqeodpzt24teiuc0.download
 safety.microsoft.com.hfypcjv.uzhcrrwfydiy62edla.review
 safety.microsoft.com.hlycyi.mk1nxmb65xvqz3me.review
 safety.microsoft.com.hngeq.vqxzysmhsvloijm12fsuswlu.download
 safety.microsoft.com.hydbequby.noucx2keqr26dfrf0y.science
 safety.microsoft.com.icavj.8z3rbjq05zbmgsbvixw8dbkquw.stream
 safety.microsoft.com.ifvfyg.khciekm6bgs.review
 safety.microsoft.com.iixbcigi.p8ilrvejm0e77oygume.bid
 safety.microsoft.com.ikxdkuu.ntx3rr9r129a.stream
 safety.microsoft.com.jgrgrxuoj.17rhshrnvsimvw0fbhe.stream
 safety.microsoft.com.jkzvgxea.pet9xeejg8pmeunmptcbewwp4w.review
 safety.microsoft.com.kfahovdvcu.qs2xsibfvo9djnhm.stream
 safety.microsoft.com.khses.kkmtzornpjgalht.trade
 safety.microsoft.com.kmknfvl.qtk1ferrv1echlmajex7zwa.bid
 safety.microsoft.com.kqjtvm.ayoktqjtl2baayjfp7vw.review
 safety.microsoft.com.kqlggyc.i1j4771pcasby0rh1ozw.trade
 safety.microsoft.com.ktkgcrb.xnfcdr24m9mxr5r6nsdi3zurug.science
 safety.microsoft.com.ladhuk.0hxozq551mvcn7lo8gid1xhg.bid
 safety.microsoft.com.lkpvfobvsw.gzeawda4gmurxi4ia.trade
 safety.microsoft.com.lrezjdfo.ir6qcit6hwparcw.stream
 safety.microsoft.com.ltugrp.5rjzodumxqo9gwsfpmxt64j9wca.stream
 safety.microsoft.com.lyonzpa.w8thcykwz8ydssliuvs.trade
 safety.microsoft.com.lyvmqjmcyrj.fwsdf8heuofi0w.review
 safety.microsoft.com.lznlijidr.qr8uuq8hnrvdl7sixwvg.science
 safety.microsoft.com.mhzpi.ulhldehvcaq9qnbjheszvsfje.science
 safety.microsoft.com.mkiuqva.ynkfb9kvkoavb8i.stream
 safety.microsoft.com.moqxrddpaz.cmympgwdi04q2w9ebpjynftps5q.download
 safety.microsoft.com.msdhqindzt.liznt0y3dnub.review
 safety.microsoft.com.mtrgof.aqljhwmgdrhd0k.trade
 safety.microsoft.com.nbddrige.96au7o5dqpgeorg.stream
 safety.microsoft.com.nhftuz.havy8py6mqilxcyt5w8ls3ppiv8.trade
 safety.microsoft.com.nnlungiz.voz1ego36zqqtq.stream
 safety.microsoft.com.npqahikwh.pxakspbxyzvbg.science
 safety.microsoft.com.nvdrbk.rtj0ov2vo8vqt7zqx1equw.stream
 safety.microsoft.com.nwtllz.1i4qnftlrh6ldkx32q.bid
 safety.microsoft.com.olhxiykia.f5tergr68kwz96yguipwg.stream
 safety.microsoft.com.oyjhcr.tvjjwqsrkvhjy15ehnltx3m.trade
 safety.microsoft.com.poovzbfwae.miqvo7fq6xroojy5yimaeq.science
 safety.microsoft.com.pqxvrxa.2a1mmk9zrvdi7ekr2xexaomi.science
 safety.microsoft.com.qjmrsv.vig0u4hw5jrr1qorz7e.bid
 safety.microsoft.com.qpckeir.qyrvz97liwe5gtg8g3k.science
 safety.microsoft.com.qqjmxf.wcqtwhtdeyj.download
 safety.microsoft.com.qsbmuzbtu.icheupem4rf.science
 safety.microsoft.com.qvduayjrkfa.kk7uq8ksczroqu4k9ve.trade
 safety.microsoft.com.qyiwvpwx.sjywudokrzikmr0aike.review
 safety.microsoft.com.rdeuxkqsto.vzoxq97oyvwuvg8u5jmotokpf0.download
 safety.microsoft.com.rflmkslzvx.r1pwuoiaxamqv60ai8czq.download
 safety.microsoft.com.rgunkyk.cdzou7znjnyo1cttkrub.download
 safety.microsoft.com.rmyyfasg.epaxruc5joe3jgqcnvwj08iw.science
 safety.microsoft.com.rpgwjg.lnon6qf0w7cnbgpdj4i31n8ww.science
 safety.microsoft.com.tdhtzz.4en6b7sktegskxuudmh.stream
 safety.microsoft.com.tgxlmdboijp.awgv2cnumarn2qbiczt5je4.review
 safety.microsoft.com.tjfbsjka.xrebzzbra18getm.science
 safety.microsoft.com.twqsnjgfevh.h60gr0ljrkdkvidiqy.science
 safety.microsoft.com.txjdj.38fmuz9i3goc.download
 safety.microsoft.com.ucxroyviued.dvhv1w9ebyndlipz1zeljprcw.bid
 safety.microsoft.com.ulxxk.rh0t4lm5euppjeuonocgvycd.science
 safety.microsoft.com.unvcjqrinz.t6taqq1vap6.bid
 safety.microsoft.com.upbjl.sowlskuvlhgyfnudm1iwrq.science
 safety.microsoft.com.uprmrng.3cafmarcurbzvgenixc8gco.bid
 safety.microsoft.com.usxluxbuodr.wyyjmkvdgxfqkupl.trade
 safety.microsoft.com.vphpbgam.h0nhsnvxkdo9aheurrjlf5mzxwm.trade
 safety.microsoft.com.vsmkfr.14rmgixfeaiarjkjcw.trade
 safety.microsoft.com.vvmkcauonvn.9fw8z1cxnoaogw1kpugaai9bca.trade
 safety.microsoft.com.wcupgelxrho.kfgdcsxcegzqyh4.review
 safety.microsoft.com.wdtil.og6wyeun0zz81akji.review
 safety.microsoft.com.wfwfc.aakkwvtvm2pp5w.review
 safety.microsoft.com.wqnzhgvhjuf.ld3bfhtmyzwyrrs.trade
 safety.microsoft.com.wxzoxm.3vd7kwm6xvufjx3xk5c.science
 safety.microsoft.com.wzlwy.ft4jegm61hzauivsok.review
 safety.microsoft.com.xagvc.u8macvasxvvtqzzfazwwdyhdmw.download
 safety.microsoft.com.xaoxdee.ca06vcr6i5q1yncioqmbbi.bid
 safety.microsoft.com.xiatpjprbfj.vevugginvtju8g.science
 safety.microsoft.com.xicqbaqt.djrroelphmrg4a0s0a.download
 safety.microsoft.com.xjjjznkzjb.ewtqeokc6fhpg.stream
 safety.microsoft.com.xllctvwaoa.urzdpmxysojfdcjwiva.science
 safety.microsoft.com.xsyxct.nqke0jutimhuexjh.bid
 safety.microsoft.com.xwdcxdnrs.gjmnfh6hk1sykauxhoma.stream
 safety.microsoft.com.xxqfd.sww60amwqryovw.download
 safety.microsoft.com.xxzmeim.jreuymjsaqiqrh4afetg.trade
 safety.microsoft.com.ybzdmyavpsa.did6kvaujuapxh.stream
 safety.microsoft.com.yctcioe.l4uytrede8rviynkfb9q.science
 safety.microsoft.com.yepxre.bmmpjnjcjrby0xz9v1ezjg.trade
 safety.microsoft.com.yocbz.3ywcz4wvd53hlpm0clgiksyaa.stream
 safety.microsoft.com.yohvwv.sn04rdvvwnsw4yal4vw4dyw.science
 safety.microsoft.com.ysaecpjpsxq.8hg5yvzr9ojobmvs1nydwa.review
 safety.microsoft.com.ywklalgc.ak3b81etsayzfvyyao6x8w.stream
 safety.microsoft.com.yxobkax.lcghizbmzcwdw593jwlb.stream
 safety.microsoft.com.zbzrdczaof.vkqyelqaea8mux46qavimhag.download
 safety.microsoft.com.zoyucqowcl.4hvc66gyo9wwhjtd2oweapo.review
 safety.microsoft.com.zpflc.dqapqnbgrftmjiw90k5vkvt.bid
 safety.microsoft.com.zwvpqsohzdw.szbv2abpzzdh5a.science
 securitycheckmicrosoft.com
 services.wes.df.telemetry.microsoft.com
 settings-sandbox.data.microsoft.com
 spynet2.microsoft.com
 sqm.df.telemetry.microsoft.com
 sqm.telemetry.microsoft.com
 sqm.telemetry.microsoft.com.nsatc.net
 statsfe2.ws.microsoft.com
Finally Resolved
It was down to me setting bing.com to strict.bing.com in dnsmasq config.
Strange when i had the same issue all I had to do was power cycle the good old box.
@MartinDEE, I'm having the same issue. Diversion and Skynet installed to an RT-AC86U running Asuswrt-Merlin's latest firmware. Both scripts are up-to-date.
At first, achievements stopped unlocking on my Xbox One X. I then gathered all the domains I could find that were required for Xbox functionality and added them to a hosted whitelist in Diversion (processing it, so Skynet would be able to "see" it as well). The full list of domains I uploaded can be found here (compiled after going through a bunch of threads on Pi-hole's subreddit and also by combing its official FAQ - same link shared by @Vexira).
Achievements started unlocking again, but only new ones - the ones that should have already been unlocked, remained locked. The "local cache is full" message also kept popping up.
You mentioned solving the issue by "setting bing.com to strict.bing.com in dnsmasq config". How do I do that in Diversion? Do I just add that domain to my hosted whitelist? Neither "bing.com" or "strict.bing.com" are there.
Have you cleared the 'blu-ray disc and persistent storage' then done a hard reset (power cycle)?
This is because for an amount of time you had the necercery domains required to unlock achievements blocked.
As a result of this when it came to achievement unlocking your Xbox was basically running offline.
The Xbox can only store a limited amount of achievements offline until it's cache is full then it stop locally storing any further achievements that are unlocked whilst 'offline'.
Try just White listing Bing.com
