XT 8 - Pihole question
Rashed4004
hey all
with my old ac68u and pihole i could force ac68u to use pihole as the only dns server but with XT8 i cant find no such option.
is there any way to do it?
thanks
On mine, looking in the LAN/LAN IP settings page, I see "Connect to DNS server automatically" which I set to OFF, then there are two fields in which I can put one or two DNS server IP addresses manually.
Not real sure if it makes a difference to this, but I also have "Get LAN IP automatically"
set to OFF further up the page. (I believe that for both of those radio buttons, "automatically" effectively means "get it from DHCP on the LAN".)
