XT8 Kernel error
lifeisfun
Any idea what can cause this error? It repeats it self in the log over and over
Nov 22 10:03:02 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 22 10:12:35 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link DOWN.
Nov 22 10:12:37 kernel: eth2: sysport_tm port shaper set to 99900 kbps, 35000 mbs (phy speed 100000 kbps)
Nov 22 10:12:37 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link Up at 100 mbps full duplex
Nov 22 10:13:07 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link DOWN.
Nov 22 10:13:09 kernel: eth2: sysport_tm port shaper set to 99900 kbps, 35000 mbs (phy speed 100000 kbps)
Nov 22 10:13:09 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link Up at 100 mbps full duplex
Nov 22 10:13:39 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link DOWN.
Nov 22 10:13:41 kernel: eth2: sysport_tm port shaper set to 99900 kbps, 35000 mbs (phy speed 100000 kbps)
Nov 22 10:13:41 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link Up at 100 mbps full duplex
Nov 22 10:15:13 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 22 10:15:48 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link DOWN.
Nov 22 10:15:50 kernel: eth2: sysport_tm port shaper set to 99900 kbps, 35000 mbs (phy speed 100000 kbps)
Nov 22 10:15:50 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link Up at 100 mbps full duplex
Nov 22 10:19:31 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 5, current 0x0001, new 0x0001^[[0m
Nov 22 10:22:54 acsd: acs_build_candidates(731): eth6: number of valid chanspec is 0
Nov 22 10:22:59 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link DOWN.
Nov 22 10:23:01 kernel: eth2: sysport_tm port shaper set to 99900 kbps, 35000 mbs (phy speed 100000 kbps)
Nov 22 10:23:01 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) (phyId: 1) Link Up at 100 mbps full duplex
Nov 22 10:23:12 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
The reason I checked the logs is that my phone once in the while disconnects from the router and then reconnects back.
Sometimes is frequent and sometimes rare.
Upgraded FW to latest, problem still there.
RMerlin
Asuswrt-Merlin dev
What`s connected to LAN port 1 of your router keeps disconnecting and reconnecting. Try replacing the Ethernet cable. If it`s a computer, it might also be going into sleep mode, which will cause these disconnects.
lifeisfun
Thank you VERY much for your reply! Will try that!
lifeisfun
Well, looks like that wasn't it, that error pops out all the time, sometimes there is 5 even 6 lines right after each other with this error.
Nov 23 13:17:18 wlceventd: wlceventd_proc_event(530): eth4: Auth xx:xx:xx:xx:xx:37, status: Successful (0), rssi:0
Nov 23 13:17:18 wlceventd: wlceventd_proc_event(559): eth4: Assocxx:xx:xx:xx:xx:37, status: Successful (0), rssi:-62
Nov 23 13:17:25 wlceventd: wlceventd_proc_event(530): eth4: Auth xx:xx:xx:xx:xx:DF, status: Successful (0), rssi:0
Nov 23 13:17:25 wlceventd: wlceventd_proc_event(559): eth4: Assoc xx:xx:xx:xx:xx:DF, status: Successful (0), rssi:-48
Nov 23 13:17:35 wlceventd: wlceventd_proc_event(494): eth4: Deauth_ind xx:xx:xx:xx:xx:89, status: 0, reason: Disassociated due to inactivity (4), rssi:-56
Nov 23 13:17:35 wlceventd: wlceventd_proc_event(494): eth4: Deauth_ind xx:xx:xx:xx:xx:89, status: 0, reason: Previous authentication no longer valid (2), rssi:-56
Nov 23 13:17:36 wlceventd: wlceventd_proc_event(511): eth4: Disassoc xx:xx:xx:xx:xx:89, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Nov 23 13:18:20 wlceventd: wlceventd_proc_event(530): eth6: Auth xx:xx:xx:xx:xx:B1, status: Successful (0), rssi:0
Nov 23 13:18:20 wlceventd: wlceventd_proc_event(559): eth6: Assoc xx:xx:xx:xx:xx:B1, status: Successful (0), rssi:-50
Nov 23 13:18:21 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 23 13:18:23 wlceventd: wlceventd_proc_event(494): eth4: Deauth_ind xx:xx:xx:xx:xx:DF, status: 0, reason: Unspecified reason (1), rssi:0
Nov 23 13:18:24 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind xx:xx:xx:xx:xx:DF, status: 0, reason: Unspecified reason (1), rssi:-54
Nov 23 13:18:24 wlceventd: wlceventd_proc_event(530): eth6: Auth xx:xx:xx:xx:xx:DF, status: Successful (0), rssi:-54
Nov 23 13:18:24 wlceventd: wlceventd_proc_event(559): eth6: Assoc xx:xx:xx:xx:xx:DF, status: Successful (0), rssi:-54
Nov 23 13:24:01 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 23 13:26:14 wlceventd: wlceventd_proc_event(530): eth4: Auth xx:xx:xx:xx:xx:89, status: Successful (0), rssi:0
Nov 23 13:26:14 wlceventd: wlceventd_proc_event(559): eth4: Assoc xx:xx:xx:xx:xx:89, status: Successful (0), rssi:-73
Nov 23 13:29:54 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 23 13:36:18 acsd: acs_build_candidates(731): eth6: number of valid chanspec is 0
Nov 23 13:37:46 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 23 13:39:34 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
RMerlin
Asuswrt-Merlin dev
lifeisfun
This is unrelated, my reply was related to this specific message:
I understand that, but any idea why this message pops up all the time?
Nov 23 14:04:29 acsd: acs_build_candidates(731): eth6: number of valid chanspec is 0
Nov 23 14:08:27 wlceventd: wlceventd_proc_event(494): eth4: Deauth_ind xx:xx:xx:xx:xx:B9, status: 0, reason: Disassociated due to inactivity (4), rssi:-59
Nov 23 14:08:27 wlceventd: wlceventd_proc_event(494): eth4: Deauth_ind xx:xx:xx:xx:xx:B9, status: 0, reason: Previous authentication no longer valid (2), rssi:-59
Nov 23 14:08:28 wlceventd: wlceventd_proc_event(511): eth4: Disassoc xx:xx:xx:xx:xx:B9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Nov 23 14:09:21 wlceventd: wlceventd_proc_event(530): eth4: Auth xx:xx:xx:xx:xx:B9, status: Successful (0), rssi:0
Nov 23 14:09:21 wlceventd: wlceventd_proc_event(559): eth4: Assoc xx:xx:xx:xx:xxB9:, status: Successful (0), rssi:-56
Nov 23 14:10:48 wlceventd: wlceventd_proc_event(494): eth4: Deauth_ind xx:xx:xx:xx:xx:B9, status: 0, reason: Disassociated due to inactivity (4), rssi:-57
Nov 23 14:10:48 wlceventd: wlceventd_proc_event(494): eth4: Deauth_ind xx:xx:xx:xx:xx:B9, status: 0, reason: Previous authentication no longer valid (2), rssi:-57
Nov 23 14:10:49 wlceventd: wlceventd_proc_event(511): eth4: Disassoc xx:xx:xx:xx:xx:B9, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Nov 23 14:18:34 acsd: acs_build_candidates(731): eth6: number of valid chanspec is 0
Nov 23 14:19:59 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 23 14:26:18 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 23 14:28:01 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 23 14:32:12 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 23 14:32:39 acsd: acs_build_candidates(731): eth6: number of valid chanspec is 0
Nov 23 14:45:02 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Nov 23 14:46:44 acsd: acs_build_candidates(731): eth6: number of valid chanspec is 0
RMerlin
Asuswrt-Merlin dev
I don't know. Archer is Boradcom`s proprietary NAT accelerator, only they know what any of these cryptic messages mean. Quite often they are just debug output, not actual error conditions.
lifeisfun
Oh, OK, thanks for the explanation! :)
