Release Notes for YazDHCP v1.0.8 production release now available
[2025-May-29]
The fork from @Jack Yaz's repository is now hosted on the AMTM-OSR GitHub repo:
github.com
1) FIXED: Errors when loading the webGUI page on the 3006.102.x F/W version.
2) FIXED: Some compatibility issues with 3006.102.x F/W version.
3) IMPROVED: Check if a USB-attached drive is mounted to back up the custom icon files.
4) IMPROVED: Check if any of the 3 files added to "dnsmasq.conf.add" are empty before actually adding them.
5) IMPROVED: Avoid restarting the dnsmasq service too often & unnecessarily.
6) IMPROVED: Modified code to set the corresponding priority level of log entries when calling the built-in logger utility.
7) IMPROVED: Added "export PATH" statement to give the built-in binaries higher priority than the equivalent Entware binaries.
8) Miscellaneous code improvements & fine-tuning.
[2025-May-29]
GitHub - AMTM-OSR/YazDHCP: Feature expansion of DHCP assignments using AsusWRT-Merlin's Addons API to read and write DHCP assignments, increasing the limit on the number of reservations.
Feature expansion of DHCP assignments using AsusWRT-Merlin's Addons API to read and write DHCP assignments, increasing the limit on the number of reservations. - AMTM-OSR/YazDHCP
