YazFi YazFi - enhanced AsusWRT-Merlin Guest WiFi inc. SSID <-> VPN Client
Can you run
arp -a
and send the line for your MAC address? (you can omit the actual MAC if you prefer)
Can you also send me the outputs of
ebtables -L
ebtables -t broute -L
and the contents of
/jffs/configs/dnsmasq.conf.add
Hi
YazFi: Querying router for connected WiFi clients...
INTERFACE: wl0.1
SSID: ASUS_Guest1
HOSTNAME IP ADDRESS MAC
4C:49:E3:B8:15:67
YazFi: Query complete, please see above for results
Redmi4X-Redmi (192.168.1.178) at 4c:49:e3:b8:15:67 [ether] on br0
ebtables -L
Bridge table: filter
Bridge chain: INPUT, entries: 0, policy: ACCEPT
Bridge chain: FORWARD, entries: 2, policy: ACCEPT
-i wl0.1 -j DROP
-o wl0.1 -j DROP
Bridge chain: OUTPUT, entries: 0, policy: ACCEPT
Bridge table: broute
Bridge chain: BROUTING, entries: 1, policy: ACCEPT
-p IPv4 -i wl0.1 --ip-dst 192.168.1.0/24 --ip-proto tcp --ip-dport ! 8083 -j DROP
cat /jffs/configs/dnsmasq.conf.add
cat: can't open '/jffs/configs/dnsmasq.conf.add': No such file or directory
Hi
INTERFACE: wl0.1
SSID: ASUS_Guest1
4C:49:E3:B8:15:67
ebtables -L
-i wl0.1 -j DROP
-o wl0.1 -j DROP
The most concerning part is that last output. Does this exist?
/jffs/configs/tmpdnsmasq.conf.add
Given that HGG didnt publish source for his forked f/w, I'm inclined to say it's not supported.
Hi
Yes the file exist and is empty
Can you send the output when you run YazFi please? (I might need to push an update to let errors appear, but lets see!)
Hi
Is this ?
/jffs/scripts# ./YazFi
YazFi: Stale lock file found (>120 seconds old) - purging lock
YazFi: YazFi v2.2.2 starting up
YazFi: wl0.1 passed validation
Hi
Is this ?
Does it not post any more output from that point? Suggests it's erroring out somewhere...let me add a "verbose" option in, will let you know when its up.
Hi
Ok, thanks for the support.
A quick fix, in the Config_Networks function:
replace
2>/dev/null
with
#2>/dev/null
Hi
./YazFi
YazFi: Adding YazFi to firewall-start
./YazFi: line 1: arithmetic syntax error
Hi
./YazFi
Do you have time to do a Teamviewer session? (PM me the join code if so)
Hi
Do you received my pm ?
I noticed this completely neutered IPv6 on my network. Setting interfaces to false and reloading allowed me to bring IPv6 back up, but it was unusable with the script enabled.
I don't touch ipv6. Another user reported ipv6 didn't work for guests but the main LAN still had access.
Found a separate unrelated configuration error causing this. Have not tested on the guest net but will try to do so.
All's well on the update.
Running the status check on this build seems much smoother and quicker. Could just be me, not sure.
