1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
Yet another AIMesh stability problem
Discussion in 'ASUS Wireless' started by Brad Isaac, Oct 5, 2018.
  1. Brad Isaac
    Brad Isaac New Around Here
    Oct 2, 2018
    5
    Hi all,
    I have tried just about everything to get AIMesh to work, but it still disconnects frequently and is unstable.
    My main router is a RT-AC68U my node is RT-AC68P. They are direct line of sight of one another about 15 feet apart. Per other suggestions here, I downgraded the firmware in both units to: 3.0.0.4.384_21140. That has made no difference.
    In looking at the logs, I see this error:
    Oct 5 19:00:10 roamast: discover candidate node [F0:79:59:7E:C0:C0](rssi: -51dbm) for weak signal strength client [14:99:E2:3D:D0:EE](rssi: -66dbm)
    Oct 5 19:00:15 roamast: discover candidate node [F0:79:59:7E:C0:C0](rssi: -42dbm) for weak signal strength client [18:B4:30:6C:A3:D5](rssi: -66dbm)
    Oct 5 19:00:40 roamast: discover candidate node [F0:79:59:7E:C0:C0](rssi: -62dbm) for weak signal strength client [E0:4F:43:D8:73:2E](rssi: -76dbm)
    Oct 5 19:00:40 roamast: roaming reject!!! candidate rssi over threshold(-55dbm)
    Oct 5 19:00:45 roamast: discover candidate node [F0:79:59:7E:C0:C0](rssi: -62dbm) for weak signal strength client [E0:4F:43:D8:73:2E](rssi: -77dbm)
    Oct 5 19:00:45 roamast: roaming reject!!! candidate rssi over threshold(-55dbm)
    Oct 5 19:00:50 roamast: discover candidate node [F0:79:59:7E:C0:C0](rssi: -61dbm) for weak signal strength client [E0:4F:43:D8:73:2E](rssi: -76dbm)
    Oct 5 19:00:50 roamast: roaming reject!!! candidate rssi over threshold(-55dbm)
    Oct 5 19:06:00 roamast: discover candidate node [F0:79:59:7E:C0:C0](rssi: -58dbm) for weak signal strength client [F0:99:B6:0A:49:4C](rssi: -73dbm)
    Oct 5 19:09:50 roamast: discover candidate node [F0:79:59:7E:C0:C0](rssi: -59dbm) for weak signal strength client [80:ED:2C:70:A7:16](rssi: -79dbm)
    Oct 5 19:09:50 roamast: roaming reject!!! candidate rssi over threshold(-55dbm)
    Oct 5 19:10:20 roamast: discover candidate node [F0:79:59:7E:C0:C0](rssi: -58dbm) for weak signal strength client [80:ED:2C:70:A7:16](rssi: -74dbm)
    Oct 5 19:10:20 roamast: roaming reject!!! candidate rssi over threshold(-55dbm)
    Why would I be getting low signal and disconnects with the routers so close?
  2. arthurlien
    arthurlien Very Senior Member
    Jul 29, 2014
    616
    Not error, the message is normal.
    Could you send feedback with System log, WiFi log by Administration->Feedback function?
  3. Brad Isaac
    Oct 2, 2018
    5
    But every time that happens my laptop goes offline.
  4. arthurlien
    Jul 29, 2014
    616
    Base on the information you provided, I only can tell you that. If you can send feedback with system log, wifi log by Administration -> Feedback, Maybe I can find more.
  5. Brad Isaac
    Oct 2, 2018
    5
    Thanks How do I get the report to you? Are you with ASUS?
  6. OzarkEdge
    OzarkEdge Very Senior Member
    Feb 14, 2018
    1,051
    USA
    Use the Feedback tab in the router GUI. Comment with your SNB userID. If the Feedback says it did not send, ignore it... I think it still sends (mine did). And ignore the Google login nonsense.
    OE
  7. RMerlin
    RMerlin Super Moderator
    Apr 14, 2012
    29,033
    Canada
    Arthur is an Asus employee. If your ISP prevents the Feedback form from working, send it to the router_feedback email address visible on the Feedback page, specifying your forum username so Arthur can link it to you.
