Fitz Mutch
I use an Asus RT-AC56U with DD-WRT firmware as my travel router because it has wireless client mode. So, here I sit in some parking lot within range of some free public Wi-Fi, trying to route a bunch of devices through Tor running on the router, but it does not work. The problem is that sometimes the router cannot sync its clock with an Internet time source, for whatever reason, and this causes problems with Tor and other services that depend on certificate validation. I discovered how to turn on the NTP Server in Windows, then have the router sync its clock with my Windows laptop on the local network. It works!! No Internet connection is required for time synchronization. Yet another way to sync your router's clock.
HOWTO: Configure Windows as an NTP Server
1. Stop Windows Time service using the Services applet
2. Regedit
4. Windows Firewall
Sync your router's clock with Windows
WebUI: Administration -> System -> Miscellaneous -> NTP Server = (ip address of my Windows laptop)
2. Regedit
Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\W32Time\Config
Value: AnnounceFlags = 5
Value: Enabled = 1
3. Start Windows Time serviceValue: AnnounceFlags = 5
Announce flag values:
0 Timeserv_Announce_No, Reliable_Timeserv_Announce_No. The domain controller does not advertise time service.
1 Timeserv_Announce_Yes. The domain controller always advertises time service.
2 Timeserv_Announce_Auto. The domain controller automatically determines whether it should advertise time service.
4 Reliable_Timeserv_Announce_Yes. The domain controller will always advertise reliable time service.
8 Reliable_Timeserv_Announce_Auto. The domain controller automatically determines whether it should advertise reliable time service.
Flag 5 (1+4) means "The domain controller always advertises time service" and "The domain controller will always advertise reliable time service".
Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\W32Time\TimeProviders\NtpServer0 Timeserv_Announce_No, Reliable_Timeserv_Announce_No. The domain controller does not advertise time service.
Value: Enabled = 1
4. Windows Firewall
Inbound Rule: New Rule -> Port -> UDP -> 123 -> Allow the connection, Name = NTP Server
