Zenwifi BT8 Manual?
joechip
I am considering replacing my 12-year old Asus router with a current Zenwifi BT8 (with one mesh satellite). Although I am not an SME, I know how to perform my desired configuration options manually through its web interface, such renaming and hiding the SSID, implementing MAC filtering, and using the parental controls.
I considered some other Asus mesh routers (e.g. ET9 and XT8), and I can easily understand their configuration options by downloading and reviewing their ~130-page operating manuals. However, in the case of the BT8, in which I think that I am finally interested, its online manual is 25% the length (~30 pages) of the others and is much higher level, not very useful for me at all. Configuration options such as the few I have listed above are not even mentioned. Furthermore, I am not even sure that the BT8 has a web interface.
There is a searchable FAQ on the Asus product web page, but some of my searches such as "SSID" and "hidden SSID" return no results.
Does the BT8 even have a web interface? Is it comparable to the web interfaces of other Asus routers? How can I determine the unit's configurable options before buying? Is there a more complete manual hiding somewhere?
In my current case, I may have to disable NAT in the router, since the upstream T-Mobile internet gateway (not yet integrated into my main home network) evidently performs NAT, and I can't access this parameter to turn it off. So, I need to learn about that.
thanks
If it's still true what I've read in the past T-Mobile service uses a gateway and unfortunately doesn't allow Bridge Mode nor IP Passthrough (AT&T's option). You'd want to set the primary BT8 as an Access Point and the other as it's AiMesh node.
Regarding the manual I just checked and it is 30 pages. But section 3 is interestingly a bunch of hyperlinks to Tutorials/FAQs online. (A good way to easily keep them up to date without having to go and revise manuals one by one)...
