ZenWifi XT8 Is there anyway other than hardwire to force a node to a closer node?
davekstl
The RT-AX3000 is on the opposite wall of the Node in the Redbox in the image. But the RT-AX3000 keeps connecting to the Main Router 75 feet away.
I have rebooted the main router and the RT several times trying to force the RT to the closest node. However no success.
Is there a process to force it to the closet node?
OzarkEdge
Part of the Furniture
AiMesh 2.0 beta RC2-7 permits setting the preferred backhaul route:
OE
davekstl
Ok...this sounds great. But here it comes, how do I install the Beta or is that a bad idea. I have a ZenWifi XT2 (2 nodes counting the router) and a RT-AX3000. How do I install it? Does it get installed on all 3 items? Where do I find it?
OzarkEdge
This is the beta thread. I have not kept up on your router models. The current beta is RC2-7, so find the page that was announced on and read forward.
My index of RC2 releases:
Beta firmware is just another firmware upload. But you should be prepared for any imperfections. Read what others post about your models and their experience.
The linked Google drive lists the model specific beta firmware. Some models have more than one model identifier, so you will have to know yours and translate accordingly. Again, read the posts by those who have gone before you and lived to tell about it.
OE
davekstl
So generically...if I install the new firmware, should the app reflect a new firmware version for the model I changed?
I am getting there .. thnaks
L&LD
'app'? If you want to test properly, don't use an app. Use the browser on a real computer (and not a handheld device).
OzarkEdge
Beta firmware is intended to behave like released firmware. So, if the firmware version changes, it will look like it should look. I would plan to run the same firmware level on all nodes, so all nodes should be running the beta firmware.
I don't use the app, so you'll have to determine how that behaves. I would not expect an app to keep up with beta firmware.
OE
OzarkEdge
OzarkEdge
Got it, it is running, so thank you
If you notice any "imperfections", report them in the beta thread to get them fixed.
OE
OzarkEdge
Can you please send the link to where I post items?
I have loaded Beta 2 on all three devices, now I am just playing.
I already linked to the beta thread above.
It's not beta 2... it's RC2-7... Release Candidate 2, build 7.
OE
