Solved ZenWifi XT9 got disconnected from AiMesh randomly, any help?
wonderiuy
Hy everyone,
i have a GT-AX6000 as main router with firmware 3.0.0.4.388.22068 and a (recently purchased) ZenWifi XT9 as AiMesh node on 3.0.0.4.388.22068
From first moment of XT9 usage it often got disconnected form AiMesh, randomly, no specific time or operation.
Before XT9 i had a RT-AC86U wich worked flawlessly.
On XT9 i've tried (re-adding as a mesh node each time):
- resetting to factory def, reflashing 3.0.0.4.388.22068
Still disconnections
- flashing previous version 3.0.0.4.388.21963, resetting
Still disconnections (but less)
- reflashing 3.0.0.4.388.22068, reset to factory def
- flashed Merlin 388.1 on GT-AX6000
Still disconnection
- flashed back GT-AX6000 to 3.0.0.4.388.22068
Still disconnection
The log on my GT-AX6000 says:
Jan 11 18:56:21 wlceventd: wlceventd_proc_event(511): wds0.0.1: Disassoc A0:36:BC:46:D8:31, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 11 18:56:21 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind A0:36:BC:46:D8:31, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jan 11 18:56:21 kernel: CFG80211-ERROR) wl_event_handler :
Jan 11 18:56:21 kernel: No wdev corresponding to bssidx: 0x0 found! Ignoring event.
Jan 11 18:56:21 kernel: wfd_unregisterdevice Successfully unregistered ifidx 1 wfd_idx 0
Jan 11 18:56:21 hostapd: eth6: STA a0:36:bc:46:d8:31 IEEE 802.11: disassociated
Jan 11 18:56:21 kernel: br0: port 7(wds0.0.1) entered disabled state
Jan 11 18:56:21 kernel: device wds0.0.1 left promiscuous mode
Jan 11 18:56:22 wlceventd: wlceventd_proc_event(530): eth6: Auth A0:36:BC:46:D8:31, status: Successful (0), rssi:0
Jan 11 18:56:22 wlceventd: wlceventd_proc_event(559): eth6: Assoc A0:36:BC:46:D8:31, status: Successful (0), rssi:-60
Jan 11 18:56:22 hostapd: eth6: STA a0:36:bc:46:d8:31 IEEE 802.11: associated
Jan 11 18:56:22 hostapd: eth6: STA a0:36:bc:46:d8:31 RADIUS: starting accounting session 8B516D4430C6865C
Jan 11 18:56:22 hostapd: eth6: STA a0:36:bc:46:d8:31 WPA: pairwise key handshake completed (RSN)
Jan 11 18:56:22 kernel: wfd_registerdevice Successfully registered dev wds0.0.1 ifidx 1 wfd_idx 0
Jan 11 18:56:22 kernel: Register interface [wds0.0.1]  MAC: 04:42:1a:60:27:80
Jan 11 18:56:22 kernel: br0: port 7(wds0.0.1) entered blocking state
Jan 11 18:56:22 kernel: br0: port 7(wds0.0.1) entered disabled state
Jan 11 18:56:22 kernel: device wds0.0.1 entered promiscuous mode
Jan 11 18:56:22 kernel: br0: port 7(wds0.0.1) entered listening state
Jan 11 18:56:24 kernel: br0: port 7(wds0.0.1) entered learning state
Jan 11 18:56:25 wlceventd: wlceventd_proc_event(511): wds0.0.1: Disassoc A0:36:BC:46:D8:31, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 11 18:56:25 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind A0:36:BC:46:D8:31, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jan 11 18:56:25 kernel: CFG80211-ERROR) wl_event_handler :
Jan 11 18:56:25 kernel: No wdev corresponding to bssidx: 0x0 found! Ignoring event.
Jan 11 18:56:25 kernel: wfd_unregisterdevice Successfully unregistered ifidx 1 wfd_idx 0
Jan 11 18:56:25 hostapd: eth6: STA a0:36:bc:46:d8:31 IEEE 802.11: disassociated
Jan 11 18:56:25 kernel: br0: port 7(wds0.0.1) entered disabled state
Jan 11 18:56:25 kernel: device wds0.0.1 left promiscuous mode
Jan 11 18:56:31 dnsmasq-dhcp[2502]: DHCPDISCOVER(br0) a0:36:bc:46:d8:30
Jan 11 18:56:31 dnsmasq-dhcp[2502]: DHCPOFFER(br0) 192.168.0.199 a0:36:bc:46:d8:30
Jan 11 18:56:31 dnsmasq-dhcp[2502]: DHCPREQUEST(br0) 192.168.0.199 a0:36:bc:46:d8:30
Jan 11 18:56:31 dnsmasq-dhcp[2502]: DHCPACK(br0) 192.168.0.199 a0:36:bc:46:d8:30
Where A0:36:BC:46:D8:31 is the MAC of the ZenWiFi XT9
Edit:
Forgot to say: backhaul is wired LAN
GT-AX6000 is connected with link aggregation (port 1 and 2) to the switch and the XT9 is connected to that switch (HP 1920S), but this was not a problem when the node was the RT-AC86U
I've tried also to disable "Private Fi-Fi Address" from my iphone (a possible cause) but disconnection still occurs
Do you have any suggestion? Is my XT9 Faulty?
Thank you for any advice
Again, after some hours of stability:
Jan 11 21:35:38 wlceventd: wlceventd_proc_event(494): eth6: Deauth_ind EC:FA:BC:6E:A1:97, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:-79
Jan 11 21:35:38 wlceventd: wlceventd_proc_event(511): eth6: Disassoc EC:FA:BC:6E:A1:97, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:-79
Jan 11 21:35:38 hostapd: eth6: STA ec:fa:bc:6e:a1:97 IEEE 802.11: disassociated
Jan 11 21:35:38 wlceventd: wlceventd_proc_event(530): eth6: Auth EC:FA:BC:6E:A1:97, status: Successful (0), rssi:-79
Jan 11 21:35:38 wlceventd: wlceventd_proc_event(559): eth6: Assoc EC:FA:BC:6E:A1:97, status: Successful (0), rssi:-79
Jan 11 21:35:38 hostapd: eth6: STA ec:fa:bc:6e:a1:97 IEEE 802.11: associated
Jan 11 21:35:38 hostapd: eth6: STA ec:fa:bc:6e:a1:97 RADIUS: starting accounting session 50071D6F77DE0E20
Jan 11 21:35:38 hostapd: eth6: STA ec:fa:bc:6e:a1:97 WPA: pairwise key handshake completed (RSN)
Jan 11 21:35:42 wlceventd: wlceventd_proc_event(530): eth6: Auth 00:03:50:BC:11:CA, status: Successful (0), rssi:0
Jan 11 21:35:42 wlceventd: wlceventd_proc_event(559): eth6: Assoc 00:03:50:BC:11:CA, status: Successful (0), rssi:-52
Jan 11 21:35:42 hostapd: eth6: STA 00:03:50:bc:11:ca IEEE 802.11: associated
Jan 11 21:35:42 hostapd: eth6: STA 00:03:50:bc:11:ca RADIUS: starting accounting session 3F6604BD91A25C31
Jan 11 21:35:42 hostapd: eth6: STA 00:03:50:bc:11:ca WPA: pairwise key handshake completed (RSN)
Jan 11 21:35:42 dnsmasq-dhcp[2502]: DHCPDISCOVER(br0) 00:03:50:bc:11:ca
Jan 11 21:35:42 dnsmasq-dhcp[2502]: DHCPOFFER(br0) 192.168.0.13 00:03:50:bc:11:ca
Jan 11 21:35:44 dnsmasq-dhcp[2502]: DHCPDISCOVER(br0) 00:03:50:bc:11:ca
Jan 11 21:35:44 dnsmasq-dhcp[2502]: DHCPOFFER(br0) 192.168.0.13 00:03:50:bc:11:ca
Jan 11 21:35:47 wlceventd: wlceventd_proc_event(530): eth7: Auth 30:FD:38:9F:D8:0E, status: Successful (0), rssi:-64
Jan 11 21:35:47 wlceventd: wlceventd_proc_event(559): eth7: Assoc 30:FD:38:9F:D8:0E, status: Successful (0), rssi:-64
Jan 11 21:35:47 hostapd: eth7: STA 30:fd:38:9f:d8:0e IEEE 802.11: associated
Jan 11 21:35:47 hostapd: eth7: STA 30:fd:38:9f:d8:0e RADIUS: starting accounting session 05626C558530CC0A
Jan 11 21:35:47 hostapd: eth7: STA 30:fd:38:9f:d8:0e WPA: pairwise key handshake completed (RSN)
Jan 11 21:35:47 dnsmasq-dhcp[2502]: DHCPREQUEST(br0) 192.168.0.14 30:fd:38:9f:d8:0e
Jan 11 21:35:47 dnsmasq-dhcp[2502]: DHCPACK(br0) 192.168.0.14 30:fd:38:9f:d8:0e Google-Home-Mini
Jan 11 21:35:48 dnsmasq-dhcp[2502]: DHCPDISCOVER(br0) 00:03:50:bc:11:ca
Jan 11 21:35:48 dnsmasq-dhcp[2502]: DHCPOFFER(br0) 192.168.0.13 00:03:50:bc:11:ca
Jan 11 21:35:48 dnsmasq-dhcp[2502]: DHCPREQUEST(br0) 192.168.0.13 00:03:50:bc:11:ca
Jan 11 21:35:48 dnsmasq-dhcp[2502]: DHCPACK(br0) 192.168.0.13 00:03:50:bc:11:ca
Jan 11 21:35:57 rc_service: cfg_server 2945:notify_rc update_sta_binding
Jan 11 21:36:13 dnsmasq-dhcp[2502]: DHCPREQUEST(br0) 192.168.0.9 14:c9:13:14:c6:ad
Jan 11 21:36:13 dnsmasq-dhcp[2502]: DHCPACK(br0) 192.168.0.9 14:c9:13:14:c6:ad LGwebOSTV
Jan 11 21:36:22 wlceventd: wlceventd_proc_event(530): eth6: Auth A0:36:BC:46:D8:31, status: Successful (0), rssi:0
Jan 11 21:36:23 wlceventd: wlceventd_proc_event(559): eth6: Assoc A0:36:BC:46:D8:31, status: Successful (0), rssi:-59
Jan 11 21:36:23 hostapd: eth6: STA a0:36:bc:46:d8:31 IEEE 802.11: associated
Jan 11 21:36:23 hostapd: eth6: STA a0:36:bc:46:d8:31 RADIUS: starting accounting session 62F9615F1086F305
Jan 11 21:36:23 hostapd: eth6: STA a0:36:bc:46:d8:31 WPA: pairwise key handshake completed (RSN)
Jan 11 21:36:23 kernel: wfd_registerdevice Successfully registered dev wds0.0.1 ifidx 1 wfd_idx 0
Jan 11 21:36:23 kernel: Register interface [wds0.0.1]  MAC: 04:42:1a:60:27:80
Nodes are having issues with at least the last two firmwares. 22068 and the one before. There is a XT8 thread here where some people are keeping the main rounder on 22068 and the nodes on an older version. That seems to be working.
Thank you, so new hardware carries old problems
XT9 has different version numbering than XT8 for the last year, i will give a try with 3.0.0.4.388.21069 and report in a few days
