pitiriguisvi
Hello,
There is no switch to enable or disable wan access in Application usb > Shared FTP > Enable wan access... Also, cant connect to ftp from the internet.
Also, if you disable the 5 GHz-1 band, you cant see the temperature of the 5 GHz-2 under Tools > Temperatures (it appears that 5 Ghz is disabled, even if you have 5 GHz-2 enabled)
