Am I Under Attack !?
IAAI
I have AC68U - Running Merlin's 42-2
I was working on the internet and suddenly got disconnected from 5GHz WiFi Switched to 2GHz and logged in to check log and found this :
May 31 05:08:19 crond[546]: time disparity of 1794848 minutes detected
May 31 05:08:30 dropbear[787]: Child connection from 116.10.191.173:20146
May 31 05:08:32 dropbear[787]: Login attempt for nonexistent user from 116.10.191.173:20146
May 31 05:08:33 dropbear[787]: Login attempt for nonexistent user from 116.10.191.173:20146
May 31 05:08:34 dropbear[787]: Login attempt for nonexistent user from 116.10.191.173:20146
May 31 05:08:35 dropbear[787]: Login attempt for nonexistent user from 116.10.191.173:20146
May 31 05:08:36 dropbear[787]: Login attempt for nonexistent user from 116.10.191.173:20146
May 31 05:08:37 dropbear[787]: Login attempt for nonexistent user from 116.10.191.173:20146
May 31 05:08:38 dropbear[787]: Login attempt for nonexistent user from 116.10.191.173:20146
May 31 05:08:39 dropbear[787]: Login attempt for nonexistent user from 116.10.191.173:20146
May 31 05:08:40 dropbear[787]: Exit before auth: Max auth tries reached - user 'is invalid' from 116.10.191.173:20146
May 31 05:08:40 dropbear[789]: Child connection from 116.10.191.173:23744
May 31 05:08:45 dropbear[789]: Login attempt for nonexistent user from 116.10.191.173:23744
May 31 05:08:46 dropbear[789]: Login attempt for nonexistent user from 116.10.191.173:23744
May 31 05:08:47 dropbear[789]: Login attempt for nonexistent user from 116.10.191.173:23744
May 31 05:08:47 kernel: br0: received packet on eth1 with own address as source address
May 31 05:08:48 dropbear[789]: Login attempt for nonexistent user from 116.10.191.173:23744
May 31 05:08:49 dropbear[789]: Login attempt for nonexistent user from 116.10.191.173:23744
May 31 05:08:50 dropbear[789]: Login attempt for nonexistent user from 116.10.191.173:23744
May 31 05:08:51 dropbear[789]: Login attempt for nonexistent user from 116.10.191.173:23744
May 31 05:08:51 dropbear[789]: Exit before auth: Max auth tries reached - user 'is invalid' from 116.10.191.173:23744
May 31 05:08:52 dropbear[790]: Child connection from 116.10.191.173:27670
May 31 05:08:54 dropbear[790]: Login attempt for nonexistent user from 116.10.191.173:27670
May 31 05:08:55 dropbear[790]: Login attempt for nonexistent user from 116.10.191.173:27670
May 31 05:08:56 dropbear[790]: Login attempt for nonexistent user from 116.10.191.173:27670
May 31 05:08:57 dropbear[790]: Login attempt for nonexistent user from 116.10.191.173:27670
May 31 05:08:58 dropbear[790]: Login attempt for nonexistent user from 116.10.191.173:27670
May 31 05:09:02 dropbear[790]: Login attempt for nonexistent user from 116.10.191.173:27670
May 31 05:09:03 dropbear[790]: Login attempt for nonexistent user from 116.10.191.173:27670
May 31 05:09:04 dropbear[790]: Login attempt for nonexistent user from 116.10.191.173:27670
May 31 05:09:04 dropbear[790]: Exit before auth: Max auth tries reached - user 'is invalid' from 116.10.191.173:27670
May 31 05:09:05 dropbear[791]: Child connection from 116.10.191.173:31985
May 31 05:09:07 dropbear[791]: Login attempt for nonexistent user from 116.10.191.173:31985
May 31 05:09:08 dropbear[791]: Login attempt for nonexistent user from 116.10.191.173:31985
May 31 05:09:09 dropbear[791]: Login attempt for nonexistent user from 116.10.191.173:31985
May 31 05:09:10 dropbear[791]: Login attempt for nonexistent user from 116.10.191.173:31985
May 31 05:09:11 dropbear[791]: Login attempt for nonexistent user from 116.10.191.173:31985
May 31 05:09:12 dropbear[791]: Login attempt for nonexistent user from 116.10.191.173:31985
May 31 05:09:13 dropbear[791]: Login attempt for nonexistent user from 116.10.191.173:31985
May 31 05:09:14 dropbear[791]: Exit before auth: Error reading: Connection reset by peer
I was running Chinese iPhone app called iTools from my computer (Copying Music)
http://www.itools.cn/multi_lang_pc_download.htm
restarted the router + Closed the app and still getting these attacks
Tracked the IP's , they come from the same location in China
"31 May 2014
116.10.191.216
116.10.191.173
ISP: China Telecom Guangxi
Nanning, Guangxi (16), China
Lat: 22.8167
Lon: 108.3167"
This one just happened
May 31 05:42:29 dropbear[892]: Exit before auth: Max auth tries reached - user 'is invalid' from 116.10.191.216:31664
May 31 05:42:29 dropbear[894]: Child connection from 116.10.191.216:35248
May 31 05:42:34 dropbear[894]: Login attempt for nonexistent user from 116.10.191.216:35248
May 31 05:42:35 dropbear[894]: Login attempt for nonexistent user from 116.10.191.216:35248
May 31 05:42:36 dropbear[894]: Login attempt for nonexistent user from 116.10.191.216:35248
May 31 05:42:37 dropbear[894]: Login attempt for nonexistent user from 116.10.191.216:35248
May 31 05:42:38 dropbear[894]: Login attempt for nonexistent user from 116.10.191.216:35248
May 31 05:42:39 dropbear[894]: Login attempt for nonexistent user from 116.10.191.216:35248
May 31 05:42:39 dropbear[894]: Exit before auth: Max auth tries reached - user 'is invalid' from 116.10.191.216:35248
May 31 05:42:39 dropbear[896]: Child connection from 116.10.191.216:38069
May 31 05:42:41 dropbear[896]: Login attempt for nonexistent user from 116.10.191.216:38069
May 31 05:42:42 dropbear[896]: Login attempt for nonexistent user from 116.10.191.216:38069
May 31 05:42:43 dropbear[896]: Login attempt for nonexistent user from 116.10.191.216:38069
May 31 05:42:44 dropbear[896]: Login attempt for nonexistent user from 116.10.191.216:38069
May 31 05:42:45 dropbear[896]: Login attempt for nonexistent user from 116.10.191.216:38069
May 31 05:42:46 dropbear[896]: Login attempt for nonexistent user from 116.10.191.216:38069
May 31 05:42:47 dropbear[896]: Login attempt for nonexistent user from 116.10.191.216:38069
May 31 05:42:47 dropbear[896]: Exit before auth: Max auth tries reached - user 'is invalid' from 116.10.191.216:38069
May 31 05:42:48 dropbear[898]: Child connection from 116.10.191.216:40365
May 31 05:42:52 dropbear[898]: Login attempt for nonexistent user from 116.10.191.216:40365
May 31 05:42:52 dropbear[898]: Exit before auth: Error reading: Connection reset by peer
I couldn't copy the rest
I just disabled SSH
Most probably the Chinese application has a backdoor listening on SSH port. Somebody is trying to connect to it but reaches the router's ssh daemon and failed to login. If you are not behind firewall (for example somewhere connected to public network) you may have trouble. Try to check which services are listening on your PC when the Chinese application is running. If nothing suspicions found the another possibility is that the application "reported" the public IP address of your router and somebody probes if there is as way to connect to it from outside.
Turn off "Allow SSH access to Wan" = problem solved. Just random botnets scanning for insecure webservers
Intressding..... how did you do this tracing? and got Google Eart to show this Picture?
anything you like to share:rolleyes:
If not for public....maybe a pm?:p
Amen... only expose services you need to have enabled...
Dropbear is fairly secure, as long as you have strong passwords/keys...
However... if you absolutely need to have SSH access...
1) Move your SSH server to another port - doesn't need to be on port 22
2) Restrict SSH to only accept access attempts from specific addresses
3) Use iptables rules to rate limit ssh connection attempts
example for #3
/usr/sbin/iptables -I INPUT -p tcp --dport 22 -i eth0 -m state --state NEW -m recent --set
/usr/sbin/iptables -I INPUT -p tcp --dport 22 -i eth0 -m state --state NEW -m recent --update --seconds 60 --hitcount 4 -j DROP
4) Look at denyhosts and fail2ban - these are mostly focused at full-blown openssh implementations, not dropbear, but they are very good
5) Use certs, not username/password pairs for ssh - again, with a strong passphrase and key length
But again, if you don't need SSH access to your routers, don't enable it.
sfx
thanks for the tip. I did try this on my IP but it seems that this only shows where the ISP headquter is located and not my area Depending on my IP.
I live in Uppsala, Sweden but my IP shows Stockholm about 100km at South in the countryside ... so the info you got about the china attac is probable all wrong When it comes to positioning. but thx anyway
(it would be nice to get area location from a IP)
I don't know much about this , but i guess it depends on how good ur ISP is , Blocking trackers from identifying ur exact location
