bridge file when to call at boot
waeking
I have created a bridge event, when would be the best time to call this file. init-start? nat-start? wan-event with wan0-init?
#!/bin/sh
ifconfig br0:net10 10.255.255.254 netmask 255.0.0.0 broadcast 10.255.255.255 down &> /dev/null
ifconfig br0:net172 172.31.255.254 netmask 255.240.0.0 broadcast 172.31.255.255 down &> /dev/null
ifconfig br0:net10 10.255.255.254 netmask 255.0.0.0 broadcast 10.255.255.255 up
ifconfig br0:net172 172.31.255.254 netmask 255.240.0.0 broadcast 172.31.255.255 up
/sbin/route del -net 10.0.0.0 netmask 255.0.0.0 gw 0.0.0.0 &> /dev/null
/sbin/route del -net 172.16.0.0 netmask 255.240.0.0 gw 0.0.0.0 &> /dev/null
/sbin/route add -net 10.0.0.0 netmask 255.0.0.0 gw 192.168.1.241 metric 128
/sbin/route add -net 172.16.0.0 netmask 255.240.0.0 gw 192.168.1.241 metric 128
EDIT: doesn't work under init-start
Well part of the problem here is you're trying to handle two different types of events w/ a single event handler. The binding of additional networks *should* work from the init-start event, but the addition/deletion of routes will require waiting until the routing tables are established (wan-start I presume). Or else have both use the wan-start event.
Thanks,
routing works in the nat-start. Perfectly
The binding doesn't work in init-start.
Does nat-start work even when the wan is down?
