hungarianhc
Hi there!
First of all, here's my goal... I want to be able to administer the NAS / Plex box / router at my parents' house remotely from my house. I'm setting them up with a new AC68P next week, and I have my own AC68 at home. I'm trying to get VPN working at my house in advance of getting it setup at their house.
I've set up two separate VPNs... PPTP and OpenVPN. For PPTP, I'm using the built-in Apple VPN client in Network Preferences. For the OpenVPN, I'm using Tunnelblick as a client. I'm using the Asus DDNS service to be able to connect to my network remotely.
So first off, PPTP... It works! I can connect to my network, and I can access my router settings at 192.168.1.1. I'm at my Asus settings. No problem. All good. However, my NAS is at 192.168.1.120, and I cannot connect to that IP. It just hangs. I thought this might be a limitation with PPTP or something so I tried with Tunnelblick / OpenVPN.
Despite PPTP working great, OpenVPN doesn't seem to be working. I'm getting a TLS authentication issue.
Can anyone help here? I'm just trying to be able to access all of my local LAN IP addresses remotely. THANKS!
Edit: I have changed my settings so that my VPN client is on 192.168.1.X as well, but this still isn't allowing me to connect to the local IPs.
2015-06-24 13:54:36 TLS_ERROR: BIO read tls_read_plaintext error: error:14082174:SSL routines:ssl3_check_cert_and_algorithm:dh key too small
2015-06-24 13:54:36 TLS Error: TLS object -> incoming plaintext read error
2015-06-24 13:54:36 TLS Error: TLS handshake failed
