Rasmus Faber
I recently bought an RT-AC68U router, but I have been having trouble fully utilizing the AC-network.
With the automatic settings, I get a 20 MHz network on channel 36.
If I try to force the bandwidth to 80 MHz, it sometimes give me a 40 MHz network on 36+40 or 52+56, but also sometimes just give me a 20 MHz network on 36 or 110.
Overriding the control channel does not make any difference.
I am currently running Merlin 378.55 firmware with unlocked CFE, but I had the same problem on stock firmware (I only modded it to try to fix the bandwidth issue).
I have verified the small bandwidth with Inssider and I can see that I cannot get close to the expected performance with my Killer 1525 ac adapter (at best I get 300/300 using 802.11ac when I should be able to get up to 867/867).
There are no other 5GHz networks nearby.
Do anyone have any pointers to what I can look into to fix this? Some debug logging I can enable or some other way to set the bandwidth?
Cheers,
Rasmus.
Cheers,
Rasmus.
