Dismiss Notice
Welcome To SNBForums
Can't connect to CherryPy services
Discussion in 'ASUS AC Routers & Adapters' started by Marrus, Nov 30, 2012.
  1. Marrus
    Marrus New Around Here
    Nov 30, 2012
    6
    SOLVED - Can't connect to CherryPy services
    I run several applications which I use port forwarding to expose so I can access them from outside of my home network.
    I run Air Video and Calibre, and a couple of python applications that use CherryPy as their embedded web server.
    After setting up a new RT-AC66U as my router, I found that port forwarding did not work for the CherryPy-based applications. Air Video and Calibre worked without any problems.
    After some more testing, I found that I can access the CherryPy apps from the PC they run on, by connecting to localhost or explicitly using the IP address.
    However, I was not able to connect using the (internal) IP address from a machine (inside my home network) other than the PC running the services.
    What's going on and how can I fix it?
  2. Marrus
    Nov 30, 2012
    6
    The following minimal cherrypy service exhibits the problem that I described.
    import cherrypy
    class HelloWorld(object):
    def index(self):
    return "Hello World!"
    index.exposed = True
    cherrypy.config.update({'server.socket_port': 30596})
    cherrypy.quickstart(HelloWorld())
  3. Marrus
    Nov 30, 2012
    6
    I figured out what was causing the problem.
    When I was setting up the router, I apparently accidentally configured the network in Windows 7 to Public rather than Home.
    I had previously configured the CherryPy services to not be accessible in a Public network.
    The solution was to change the network location to Home.
Share This Page
