Can't connect to OpenVPN
nfshp253
I have an OpenVPN configuration that I've failed to get working on my AC68U. The VPN status does show TCP/UDP read bytes, Auth read bytes and TCP/UDP write bytes but all other information is at 0. The OpenVPN configuration page shows service state as On but when using my computer, it's obvious the VPN isn't connected. Can someone help me with this?
Here's the log:
https://dl.dropboxusercontent.com/u/22096700/openvpn.txt
Well I've tried those settings and for some reason it doesn't connect. I've read somewhere that TUN/TAP numbers at 0 means failure to tunnel the devices I've chosen through the VPN?
Edit: I've just tried "Redirect internet traffic" to "All traffic" and it works, which means I'm doing the policy rules wrongly. It's just selecting the devices I want (Source IP) to go through the VPN and leaving Destination IP blank, no?
I have only one device going through the VPN, set as follows:
I tried that but that didn't do anything. I set that to 192.168.1.85, which is my desktop's IP address, but it does not pass through the VPN. Is it possible that there's some complications caused by the fact that my desktop is behind another wireless router but with DHCP disabled (AC68U assigns its IP address)?
i have problem with configuering open vpn too....i do not know what i am doing wrong....here is log if someone can got solution for solve my problem....
Feb  8 14:51:54 openvpn[1202]: 89.142.232.152:54330 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Feb  8 14:51:54 openvpn[1202]: 89.142.232.152:54330 TLS Error: TLS handshake failed
Feb  8 14:51:54 openvpn[1202]: 89.142.232.152:54330 SIGUSR1[soft,tls-error] received, client-instance restarting
Feb  8 14:51:54 openvpn[1202]: 192.168.200.153:62444 TLS: Initial packet from [AF_INET]192.168.200.153:62444, sid=46df5664 da321206
Feb  8 14:51:54 openvpn[1373]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb  8 14:51:54 openvpn[1373]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Feb  8 14:51:54 openvpn[1373]: UDPv4 link local: [undef]
Feb  8 14:51:54 openvpn[1373]: UDPv4 link remote: [AF_INET]89.142.232.152:1194
Feb  8 14:51:54 openvpn[1202]: 89.142.232.152:50702 TLS: Initial packet from [AF_INET]89.142.232.152:50702, sid=bbfaaa16 6622e704
Feb  8 14:51:54 openvpn[1373]: TLS: Initial packet from [AF_INET]89.142.232.152:1194, sid=5aed2c51 c50ef6d7
Feb  8 14:51:55 openvpn[1202]: 192.168.200.153:59113 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Feb  8 14:51:55 openvpn[1202]: 192.168.200.153:59113 TLS Error: TLS handshake failed
Feb  8 14:51:55 openvpn[1373]: VERIFY ERROR: depth=1, error=self signed certificate in certificate chain: C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC68U, emailAddress=me@myhost.mydomain
Feb  8 14:51:55 openvpn[1202]: 192.168.200.153:59113 SIGUSR1[soft,tls-error] received, client-instance restarting
Feb  8 14:51:55 openvpn[1373]: TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
Feb  8 14:51:55 openvpn[1373]: TLS Error: TLS object -> incoming plaintext read error
Feb  8 14:51:55 openvpn[1373]: TLS Error: TLS handshake failed
Feb  8 14:51:55 openvpn[1373]: SIGUSR1[soft,tls-error] received, process restarting
Feb  8 14:51:55 openvpn[1373]: Restart pause, 2 second(s)
Feb  8 14:51:56 openvpn[1202]: 192.168.200.153:57094 TLS: Initial packet from [AF_INET]192.168.200.153:57094, sid=826f05b3 21c84a98
Feb  8 14:51:57 openvpn[1202]: 89.142.232.152:51255 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Feb  8 14:51:57 openvpn[1202]: 89.142.232.152:51255 TLS Error: TLS handshake failed
Feb  8 14:51:57 openvpn[1202]: 89.142.232.152:51255 SIGUSR1[soft,tls-error] received, client-instance restarting
Feb  8 14:51:57 openvpn[1202]: 192.168.200.153:59114 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Feb  8 14:51:57 openvpn[1202]: 192.168.200.153:59114 TLS Error: TLS handshake failed
Feb  8 14:51:57 openvpn[1202]: 192.168.200.153:59114 SIGUSR1[soft,tls-error] received, client-instance restarting
Feb  8 14:51:57 openvpn[1373]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb  8 14:51:57 openvpn[1373]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Feb  8 14:51:57 openvpn[1373]: UDPv4 link local: [undef]
Feb  8 14:51:57 openvpn[1373]: UDPv4 link remote: [AF_INET]89.142.232.152:1194
Feb  8 14:51:57 openvpn[1202]: 89.142.232.152:50833 TLS: Initial packet from [AF_INET]89.142.232.152:50833, sid=a0709db2 247f220b
Feb  8 14:51:57 openvpn[1373]: TLS: Initial packet from [AF_INET]89.142.232.152:1194, sid=72209274 1790b4ee
Feb  8 14:51:57 openvpn[1373]: VERIFY ERROR: depth=1, error=self signed certificate in certificate chain: C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC68U, emailAddress=me@myhost.mydomain
Feb  8 14:51:57 openvpn[1373]: TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
Feb  8 14:51:57 openvpn[1373]: TLS Error: TLS object -> incoming plaintext read error
Feb  8 14:51:57 openvpn[1373]: TLS Error: TLS handshake failed
Feb  8 14:51:57 openvpn[1373]: SIGUSR1[soft,tls-error] received, process restarting
Feb  8 14:51:57 openvpn[1373]: Restart pause, 2 second(s)
Feb  8 14:51:59 openvpn[1202]: 89.142.232.152:46959 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Feb  8 14:51:59 openvpn[1202]: 89.142.232.152:46959 TLS Error: TLS handshake failed
Feb  8 14:51:59 openvpn[1202]: 89.142.232.152:46959 SIGUSR1[soft,tls-error] received, client-instance restarting
Feb  8 14:51:59 openvpn[1202]: 192.168.200.153:57095 TLS: Initial packet from [AF_INET]192.168.200.153:57095, sid=919d25fd 894447ef
Feb  8 14:51:59 openvpn[1373]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb  8 14:51:59 openvpn[1373]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Feb  8 14:51:59 openvpn[1373]: UDPv4 link local: [undef]
Feb  8 14:51:59 openvpn[1373]: UDPv4 link remote: [AF_INET]89.142.232.152:1194
Feb  8 14:51:59 openvpn[1202]: 89.142.232.152:46392 TLS: Initial packet from [AF_INET]89.142.232.152:46392, sid=79e64147 47420dd7
Feb  8 14:51:59 openvpn[1373]: TLS: Initial packet from [AF_INET]89.142.232.152:1194, sid=14d315c6 b21fcf0e
Feb  8 14:51:59 openvpn[1373]: VERIFY ERROR: depth=1, error=self signed certificate in certificate chain: C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC68U, emailAddress=me@myhost.mydomain
Feb  8 14:51:59 openvpn[1373]: TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
Feb  8 14:51:59 openvpn[1373]: TLS Error: TLS object -> incoming plaintext read error
Feb  8 14:51:59 openvpn[1373]: TLS Error: TLS handshake failed
Feb  8 14:51:59 openvpn[1373]: SIGUSR1[soft,tls-error] received, process restarting
Feb  8 14:51:59 openvpn[1373]: Restart pause, 2 second(s)
Feb  8 14:52:00 openvpn[1202]: 192.168.200.153:60687 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Feb  8 14:52:00 openvpn[1202]: 192.168.200.153:60687 TLS Error: TLS handshake failed
Feb  8 14:52:00 openvpn[1202]: 192.168.200.153:60687 SIGUSR1[soft,tls-error] received, client-instance restarting
Feb  8 14:52:00 openvpn[1202]: 89.142.232.152:40198 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Feb  8 14:52:00 openvpn[1202]: 89.142.232.152:40198 TLS Error: TLS handshake failed
Feb  8 14:52:00 openvpn[1202]: 89.142.232.152:40198 SIGUSR1[soft,tls-error] received, client-instance restarting
Feb  8 14:52:01 openvpn[1373]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb  8 14:52:01 openvpn[1373]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Feb  8 14:52:01 openvpn[1373]: UDPv4 link local: [undef]
Feb  8 14:52:01 openvpn[1373]: UDPv4 link remote: [AF_INET]89.142.232.152:1194
Feb  8 14:52:01 openvpn[1202]: 89.142.232.152:36138 TLS: Initial packet from [AF_INET]89.142.232.152:36138, sid=c9e8dbab e106d501
Feb  8 14:52:01 openvpn[1373]: TLS: Initial packet from [AF_INET]89.142.232.152:1194, sid=e37f44af d6c64dd6
Feb  8 14:52:01 openvpn[1202]: 192.168.200.153:60834 TLS: Initial packet from [AF_INET]192.168.200.153:60834, sid=a655342f f942ad9a
Feb  8 14:52:01 openvpn[1373]: VERIFY ERROR: depth=1, error=self signed certificate in certificate chain: C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC68U, emailAddress=me@myhost.mydomain
Feb  8 14:52:01 openvpn[1373]: TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
Try assigning the router's (wifi extender) IP to your VPN policy.
Okay, I've tried assigning 192.168.1.100 which is the router's IP address but that doesn't work either. I keep seeing this in the logs: event_wait : Interrupted system call (code=4)
Who is your VPN provider?
One thing to note. Mine refused to work also, until I had set all settings and forced a reboot of router, for some unknown reason? You could try that.
I did the reboot many times but that didn't help. I'm using StrongVPN.
Edit: I've read that the interrupted system call is inconsequential as it happens whenever I click on the VPN settings tab. However, it seems like the problem is with a failure to policy route properly.
Anyone? It's strange that there are no error messages whatsoever but nothing I put in the routing rules work. OpenVPN definitely works as it connects and is able to direct all traffic through it if I selected that. But I really wish to use the 'Policy Rules'.
How are you testing to determine if traffic is routed through the tunnel or not?
I mean when I select Redirect Internet Traffic --> All Traffic, the VPN works just fine. When set to Policy rules, it connects but doesn't pass any device's data through it. In this situation, TUN/TAP read bytes, TUN/TAP write bytes are at 0 while TCP/UDP read bytes, TCP/UDP write bytes and Auth read bytes do increase over time. I'm guessing this means that the VPN connects but those 'Rules for routing client traffic through the tunnel' isn't working.
Use a site such as WhatismyIP to determine how your traffic is being routed.
With policy rules, it's my ISP's WAN IP. On All Traffic, it's the IP for my VPN server (in Hong Kong).
What did you put in the policy rules?
I selected my desktop's IP from the list (192.168.1.85) and left the destination blank, Iface as VPN. After adding the entry, the Destination IP goes to 0.0.0.0, which I believe is correct. That's it. It should work, right?
That's correct yes, assuming you have the right source IP.
