Certificate Verification issue with RT-N66U
programatix
I'm new with AsusWRT-Merlin and I'm encountering problem accessing HTTPS site from SSH.
When I tried executing WGET with HTTPS, I get, "ERROR: cannot verify ... certificate".
The same thing happen when I tried to use EASY_INSTALL. It would complain SSL: CERTIFICATE_VERIFY_FAILED.
Apparently from the search in the internet, I came to understand that I'm missing the CA certs in the router. However, I couldn't find the way to install or update them.
Any would be greatly appreciated. Thanks in advance.
I also await with interest an authoritative answer to your question.
In the meantime, did you see what you get if you try the same thing from Putty or from a Linux terminal?
Reading around it seems server authentication using certificates in ssh, rather than (or as well as?) the standard hashed fingerprint, is a relatively recent introduction and not all that common.
Use Curl instead. I configured it to use a CA bundle that I added to the firmware, but the wget build Asus added a few months ago does not point to the same CA list.
You can also manually point wget to the CA bundle:
wget https://www.google.com --ca-certificate=/rom/ca-bundle.crt
I now encountering more problem related to root certificate. Python scripts that accessed HTTPS site also have this very same issue. Is there a way to make Python to point to the CA bundle?
Since Python is not part of the firmware, that will be up to whoever packaged your Python build.
Ok. I think I resolved the problem. It turns out that I just need to install the ca-certificates package. A simple,
opkg install ca-certificates
resolves the issue.
Thanks for all the help.
