keef
I needed to reset this router to clear out the old credentials. Following the instructions, some lights flashed and things looked ok. Now the power light is on as well as the connected lan cable and I cannot ping it. No other lights are on.
Pressing reset does nothing at all now, no lights change at all. I tried a 30/30/30 with no luck. Is the router bricked? I hope not it is not even mine.
any help is very much appreciated, guys.
thanks, Bj
thanks, Bj
