I see lots of posts asking questions about "did you do this?" "did you do that"? after problems after updates, but they never seem to explain what one SHOULD have done.
There are some vague and ambiguous suggestions in the Installation instructions. It would be really helpful if there were update instructions separate from install instructions, and specific advice for specific major builds.
While it is generally not necessary to restore to factory defaults, it's not a bad idea
It is not recommended to restore settings saved under a different firmware version. It might work, but there is no guarantee
So, "it's not a bad idea", but restore to factory defaults, but then if you do, it's suggested to restore to factory defaults, and then to manually set everything back up again?
That's pretty painful.
Will I get useful information from the backup files? Are they all text that will make some sense, or are some binary and not useful for setting things up again? Or do I need to make a zillion screenshots?
Edit: OK, I see the Settings_RT-AC88U.CFG backup file is binary, and completely useless for manually restoring settings. So, screen shots it is?
The backup_jffs.tar file when untared has some readable files, but precious few files at all.
I've had huge WiFi troubles since updating to 382.1.2 from 380.68.4, which has gotten progressively worse. I need to reboot several times a day now. I see a new update is now available (384.3.0).
Can somebody recommend a specific update procedure?
Also, I notice people asking "did you download or did you use the built-in update" (I'm paraphrasing). AFAIK, there is no longer a built-in update, it just directs your browser to the download site.
Edit: from reading the release notes, I'm guessing that GPL 382 was/is a stinker. But no specifics. Release notes just say "various problems". Is it likely it's responsible for my WiFi woes? At first it works, but at some point devices start disconnecting/reconnecting and very bad performance when accessing the Internet from WiFi devices. Yet, strangely, no degraded performance to the router itself. (I use WiFi Sweet Spots). I haven't tested performance to local PC, etc, though.
