crash WAN port on 380.65
h0perman
Hello.
I have issue in 380.65
I am use old config from 380.64
Router - RT-AC68U
Connect restored when i am power OFF-ON or unplug/plug wan cable.
syslog in attachment. (ziped)
reset to factory settings and configure the new did not try.
returned back to 380.64
  • log.txt.zip.txt
What's the detail symptom?
My 68U may have the similar issue on 380.65.
Dualwan, lost wan connection at the midnight every couple days. Although the primary wan is still connected, the Internet is extremely slow.
A soft reboot thru webui or app will bring the router into a weird mode that no 2.4G or 5G signal at all.
Have to power cycle to get it back to normal. But only lasts couple days.
Downgrade to 380.64_2, running smoothly without any issue.
My bad, the same no wireless after soft reboot issue happened again on 380.64_2.
So I upgraded to 380.65 again. This time I did a factory reset. Disabled dualwan mode, manually configured settings and scripts.
Would like to see how long it can last.
