My DIR-655 seems to have severe problems dealing with power losses. It is connected to a UPS, but when the UPS gives out, as it has done a couple of times when I was not around...
I have a static IP for my internet service, and one time, the router was assigning the static IP address to a DHCP client on the LAN side!
Another time, the router would not recognize one of the PC's on my LAN, despite moving the Ethernet cable to another port that was still working (where another wired PC was connected and had no issues seeing the router).
The reset button doesn't seem to have an effect. Leaving it unplugged for a minute or two does not let it recover. Various combinations of holding the reset button for 5 or 10 seconds, and holding the reset button as I plug in the power did not work. The first two times, I had given up on it for dead, was planning on getting a new router, when it recovered.
Two of the times on recovery, the router went back to factory settings...which was a pain setting everything back up again.
Is there a magic sequence to recovering the router when power is lost?
Based on my experience, I would not buy another one. Being able to gracefully handle a power loss should be an important feature of a "backbone" type of device for my home network.
Thanks!
Thanks!
