Hi there.
I'l be using two internet connections at home (one cable and one ADSL) and I'm searching for dual WAN routers that have the ability to direct some protocols to a specified WAN port.
I'd like to direct all the traffic from my desktop to the cable WAN (direct by IP) and separate the download/upload protocols from my torrent client to use specific WAN ports (donwloads on ADSL and uploads on both connections).
Is it possible to do that on TP-Link TL-R470T+ and TL-R480T+?
I don't know exactly where should I configure this on it.
The demos are:
http://www.tp-link.com/resources/simulator/TL-R470T+/userRpm/Index.htm
http://www.tp-link.com/resources/simulator/TL-R480T+/userRpm/Index.htm
Thanx.
The demos are:
Thanx.
