Dismiss Notice
Welcome To SNBForums
Disconnects
Discussion in 'ASUS N Routers & Adapters' started by spacemunk, Jan 13, 2013.
  1. spacemunk
    spacemunk New Around Here
    Jan 13, 2013
    2
    Been using the n56u with padavan fw for my ADSL connection sometime now and everyday i have been getting disconnections like crazy.
    I have 0 knowledge when it comes to networking so i hope a kind soul could help me out please.
    Modem - TP-Link TD 8840T
    Router - Asus RT-N56U with Padavan FW 3.0.3.1v-027
    NIC - D-Link DGE-528T Gigabit PCIe Adapter
    Modem - Bridged mode DHCP off
    Router - nothing touched except entering userid + password
    And at the time of the events taking place
    lights on modem - power , adsl , lan are on
    lights on router all are on
    And also this never happens when i only have the modem connected to pc
    Below is the logs on the router
    Jan 12 18:46:33 pppd[3050]: No response to 10 echo-requests
    Jan 12 18:46:33 pppd[3050]: Serial link appears to be disconnected.
    Jan 12 18:46:33 pppd[3050]: Connect time 829.4 minutes.
    Jan 12 18:46:33 pppd[3050]: Sent 52807430 bytes, received 149326591 bytes.
    Jan 12 18:46:33 RT-N56U: wan down (ppp0)
    Jan 12 18:46:33 PPPoE: Disconnected
    Jan 12 18:46:39 pppd[3050]: Connection terminated.
    Jan 12 18:46:39 pppd[3050]: Sent PADT
    Jan 12 18:46:39 pppd[3050]: Modem hangup
    Jan 12 18:47:25 pppd[3050]: Timeout waiting for PADO packets
    Jan 12 18:47:25 wan: perform manual connect
    Jan 12 18:47:25 stop_wan(): raise DHCP release event
    Jan 12 18:47:26 pppd[3050]: Unable to complete PPPoE Discovery
    Jan 12 18:47:26 pppd[3050]: Terminating on signal 15
    Jan 12 18:47:26 pppd[3050]: Exit.
    Jan 12 18:47:26 RT-N56U: Hardware NAT/Routing: Enabled, IPoE/PPPoE offload [WAN]<->[LAN]
    Jan 12 18:47:26 RT-N56U: Hardware NAT/Routing: IPv4 UDP flow offload - OFF
    Jan 12 18:47:26 RT-N56U: Hardware NAT/Routing: IPv6 routes offload - OFF
    Jan 12 18:47:26 dnsmasq[403]: read /etc/hosts - 4 addresses
    Jan 12 18:47:26 dnsmasq[403]: read /etc/storage/hosts - 0 addresses
    Jan 12 18:47:26 dnsmasq[403]: using nameserver 8.8.4.4#53
    Jan 12 18:47:26 dnsmasq[403]: using nameserver 8.8.8.8#53
    Jan 12 18:47:26 DHCP WAN Client: starting wan dhcp (eth2.2) ...
    Jan 12 18:47:26 pppd[19938]: Plugin rp-pppoe.so loaded.
    Jan 12 18:47:26 pppd[19938]: RP-PPPoE plugin version 3.11 compiled against pppd 2.4.5
    Jan 12 18:47:26 pppd[19939]: pppd 2.4.5 started by spacemunk, uid 0
    Jan 12 18:48:01 pppd[19939]: Timeout waiting for PADO packets
    Jan 12 18:48:36 pppd[19939]: PPP session is 27483 (0x6b5b)
    Jan 12 18:48:36 pppd[19939]: Connected to 78:1d:ba:56:48:3c via interface eth2.2
    Jan 12 18:48:36 pppd[19939]: Using interface ppp0
    Jan 12 18:48:36 pppd[19939]: Connect: ppp0 <--> eth2.2
    Jan 12 18:48:36 pppd[19939]: Remote message: Authentication success,Welcome!
    Jan 12 18:58:37 pppd[19939]: No response to 10 echo-requests
    Jan 12 18:58:37 pppd[19939]: Serial link appears to be disconnected.
    Jan 12 18:58:37 pppd[19939]: Connect time 10.0 minutes.
    Jan 12 18:58:37 pppd[19939]: Sent 1095149 bytes, received 1731724 bytes.
    Jan 12 18:58:37 RT-N56U: wan down (ppp0)
    Jan 12 18:58:37 PPPoE: Disconnected
    Jan 12 18:58:43 pppd[19939]: Connection terminated.
    Jan 12 18:58:43 pppd[19939]: Sent PADT
    Jan 12 18:58:43 pppd[19939]: Modem hangup
    Jan 12 18:58:53 pppd[19939]: PPP session is 27622 (0x6be6)
    Jan 12 18:58:53 pppd[19939]: Connected to 78:1d:ba:56:48:3c via interface eth2.2
    Jan 12 18:58:53 pppd[19939]: Using interface ppp0
    Jan 12 18:58:53 pppd[19939]: Connect: ppp0 <--> eth2.2
    Jan 12 18:59:23 pppd[19939]: LCP: timeout sending Config-Requests
    Jan 12 18:59:23 pppd[19939]: Connection terminated.
    Jan 12 18:59:23 pppd[19939]: Sent PADT
    Jan 12 18:59:23 pppd[19939]: Modem hangup
    And earlier today i did a full reset on both the modem and router. Again it happened.
    Jan 13 18:21:17 pppd[1247]: No response to 10 echo-requests
    Jan 13 18:21:17 pppd[1247]: Serial link appears to be disconnected.
    Jan 13 18:21:17 pppd[1247]: Connect time 357.0 minutes.
    Jan 13 18:21:17 pppd[1247]: Sent 1165922362 bytes, received 3428396896 bytes.
    Jan 13 18:21:17 RT-N56U: wan down (ppp0)
    Jan 13 18:21:17 PPPoE: Disconnected
    Jan 13 18:21:23 pppd[1247]: Connection terminated.
    Jan 13 18:21:23 pppd[1247]: Sent PADT
    Jan 13 18:21:23 pppd[1247]: Modem hangup
    Jan 13 18:22:08 pppd[1247]: Timeout waiting for PADO packets
    Jan 13 18:22:21 detect_link: Perform WAN DHCP renew...
    Jan 13 18:22:27 wan: perform manual connect
    Jan 13 18:22:27 stop_wan(): raise DHCP release event
    Jan 13 18:22:27 RT-N56U: wan down (eth2.2)
    Jan 13 18:22:27 DHCP WAN Client: deconfig: lease is lost
    Jan 13 18:22:27 pppd[1247]: Unable to complete PPPoE Discovery
    Jan 13 18:22:27 pppd[1247]: Terminating on signal 15
    Jan 13 18:22:27 pppd[1247]: Exit.
    Jan 13 18:22:28 RT-N56U: Hardware NAT/Routing: Enabled, IPoE/PPPoE offload [WAN]<->[LAN]
    Jan 13 18:22:28 RT-N56U: Hardware NAT/Routing: IPv4 UDP flow offload - OFF
    Jan 13 18:22:28 RT-N56U: Hardware NAT/Routing: IPv6 routes offload - OFF
    Jan 13 18:22:28 dnsmasq[425]: read /etc/hosts - 4 addresses
    Jan 13 18:22:28 dnsmasq[425]: read /etc/storage/hosts - 0 addresses
    Jan 13 18:22:28 dnsmasq[425]: using nameserver 8.8.4.4#53
    Jan 13 18:22:28 dnsmasq[425]: using nameserver 8.8.8.8#53
    Jan 13 18:22:28 DHCP WAN Client: starting wan dhcp (eth2.2) ...
    Jan 13 18:22:28 pppd[3078]: Plugin rp-pppoe.so loaded.
    Jan 13 18:22:28 pppd[3078]: RP-PPPoE plugin version 3.11 compiled against pppd 2.4.5
    Jan 13 18:22:28 pppd[3080]: pppd 2.4.5 started by spacemunk, uid 0
    Jan 13 18:22:28 RT-N56U: wan up (eth2.2)
    Jan 13 18:22:28 DHCP WAN Client: bound (eth2.2), IP: 192.168.x.xxx, GW: 192.168.1.1, lease time: 259200
    Jan 13 18:23:03 pppd[3080]: Timeout waiting for PADO packets
    Jan 13 18:24:18 pppd[3080]: Timeout waiting for PADO packets
    Jan 13 18:24:53 pppd[3080]: PPP session is 1722 (0x6ba)
    Jan 13 18:24:53 pppd[3080]: Connected to 78:1d:ba:56:48:3c via interface eth2.2
    Jan 13 18:24:53 pppd[3080]: Using interface ppp0
    Jan 13 18:24:53 pppd[3080]: Connect: ppp0 <--> eth2.2
    Jan 13 18:24:53 pppd[3080]: Remote message: Authentication success,Welcome!
    Jan 13 18:24:53 pppd[3080]: PAP authentication succeeded
    Jan 13 18:24:53 pppd[3080]: peer from calling number 78:1D:BA:56:48:3C authorized
    Jan 13 18:24:53 pppd[3080]: local IP address 58.11.xxx.xxx
    Jan 13 18:24:53 pppd[3080]: remote IP address 58.11.xxx.x
    Jan 13 18:24:53 RT-N56U: wan up (ppp0)
    Jan 13 18:24:53 PPPoE: connect to ISP
    These disconnections is doing my head in. Hopefully someone could help out.
    Thanks.
  2. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    20,013
    Canada
    These sound like either an ISP or a modem issue to me, unrelated to the router itself. If power cycling your modem doesn't help, contact your ISP so they can have a look at your line stats.
  3. spacemunk
    Jan 13, 2013
    2
    Thanks RMerlin will look into it
  4. jaydam
    jaydam New Around Here
    Jan 14, 2013
    3
    I have had this router for a month and never in my life had so much agro with a router,
    the disconnects were relentless and the wireless was dire!!
    I have tried virtually every firmware there is and im fairly cute around networks and pcs and have a good understanding.
    I have read post after post and thread after thread and the bottom line is this router doesnt like going over 50 Meg,
    I have tried the asus firmware and padavans firmware and am spending more time trying to fix this asus crap than actually using my pc.
    I have been getting grief from all of the family that are trying to use the internet.
    Today i have hit a wall and had enough and returned the router to amazon as i am sick of the sight of it.
    Dont be fobbed off with isp issues etc i would say send it back as its a bucket of agro.
    read around the net and see the amount of people having trouble with it compared to the amount of people that actually get a resolve to the problem.
    you shouldnt have to be fixing £90 router as soon as you purchase it.
    /2cents rant over :)
  5. dsl2cable
    dsl2cable Occasional Visitor
    Jan 7, 2012
    20
    I also have the same router and I also tried all the firmwares. firmware version 1.0.1.7f works for me as the others firmware had disconnections problems.
  6. jaydam
    Jan 14, 2013
    3
    My New Cisco is rock solid :)
    and i have also purchased the wireless range extender to serve upstairs,
    5 bars all around the house is wicked!!
  7. dsl2cable
    Jan 7, 2012
    20
    Which model???
  8. jaydam
    Jan 14, 2013
    3
    Cisco E4500
Share This Page
