Download Master won't stop uploading
Discussion in 'ASUS AC Routers & Adapters' started by bobloblaw, Nov 7, 2012.
  1. bobloblaw
    bobloblaw Occasional Visitor
    Nov 7, 2012
    19
    Hi there, I'm hoping someone can help me with a bit of an issue I've been having recently.
    I just checked my network usage stats with my ISP and I have uploaded about 20GB in the past two days. I checked the traffic monitor in the Asus admin area and I could see that I was transmitting data but I had no programs on my laptop accessing the internet that heavily. I noticed this traffic stops when I disable download master but there are no existing tasks when I go to the download master control panel, nothing downloading or uploading.
    Is it possible there is a hung torrent that just won't quit and it somehow not visible from the control panel? I have tried to reflash my firmware (Merlin's latest) to stock then back to Merlin, nothing changed. I tried the download master upgrade but it still transmits every time I re-enable it.
    Any ideas how I could be sure that all torrents are cleared or any other ideas are greatly welcome.
    Thanks,
  2. Log in / Register to remove this ad
  3. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    16,634
    Canada
    Your traffic probably comes from the aMule service. Change the aMule server to point to itself (127.0.0.1) to at least limit it.
    Quite honestly, Asus needs to implement an option to disable aMule, and by default aMule should be disabled. A lot of people accidentally end up sharing files over aMule, causing lots of traffic - some of which on metered connections.
  4. bobloblaw
    Nov 7, 2012
    19
    Hi Merlin, thanks for the tip.
    I changed the amule service to connect to localhost like you advised, i disconnected and reconnected etc but I am still seeing traffic when download master is enabled. It seems to rise steadily starting at nothing each time it is re-enabled.
    At the moment I have no torrents active, amule service is disconnected but pointing to localhost and nothing configured in the nzb tab.
  5. RMerlin
    Apr 14, 2012
    16,634
    Canada
    Connect to your router over telnet, then locate the name of the amule process (I forgot what it is - possibly dm2_amule):
    Once you found it, look at the PID number next to it (there might be more than one), and kill those amule processes:
    See if your traffic is back to normal. If it is, then it confirms that the problem is aMule. Let me know, and I'll guide you on how to disable it completely in its startup script.
  6. bobloblaw
    Nov 7, 2012
    19
    Thanks Merlin, I just got in from work and am trying to connect to the router with telnet. i am getting an error 'could not connect to host, on port 23: connection failed. Not sure if I have to enable telnet on the router first?
    I am using stock 3.0.0.4.246 firmware
  7. bobloblaw
    Nov 7, 2012
    19
    Merlin, you were absolutely right!
    I reflashed your latest firmware in order to get to Tools>Run CMD, i ran the commands above and stopped the amule process ID with the lowest number (there are quite a few, in my case PID 1205)the uploading went back to normal instantly.
    If you could help me stop amule from starting up all together that would be great. Hopefully this will stop anyone else getting a nasty surprise on their next bill from their isp.
  8. RMerlin
    Apr 14, 2012
    16,634
    Canada
    You will need to modify the following file:
    Edit it, and search for this line:
    Remove that line - it's what starts amule. Then reboot your router.
    If you are not familiar with vi, copy that file to your USB disk, edit it from your PC, then copy it back in place. For example:
    then once you have edited it, put it back:
    Note that this file will be overwritten whenever you update Download Master to a new version, so you might want to keep a copy of it at hand.
  9. bobloblaw
    Nov 7, 2012
    19
    I'm not sure if I tried this the correct way but I copied the following line into the Run CMD tab in your firmware
    and got
    Now I'm just wondering if I would have root access but default
  10. RMerlin
    Apr 14, 2012
    16,634
    Canada
    Enable Telnet on the System -> Administration page, then use a program like Putty to connect over telnet. It will be easier then to troubleshoot path issues.
  11. bobloblaw
    Nov 7, 2012
    19
    Thanks, I have found the file in the following directory using putty
    just attempting to copy it to the Download2 directory at the moment
  12. bobloblaw
    Nov 7, 2012
    19
    Strange thing, now i can't access download master or add torrents, it is asking me for the changed port in the Download master utility and can't access it in the browser. When I edited the S50downloadmaster file there were 3 instances of:
    I deleted all three, went back to the USB disk menu and it show downloadmaster as uninstalled. I reinstalled it and now when i click the link I get the following page in Chrome
    On the upside, the transmitted data is now close to 0!:rolleyes:
  13. bobloblaw
    Nov 7, 2012
    19
    Seems to be in a loop. When i copy the edited S50downloadmaster file to the correct directory, it then asks me to install download master in the usb disk page. Then when i reinstall it, I have to copy the new edited file.
  14. RMerlin
    Apr 14, 2012
    16,634
    Canada
    After modifying this script, try rebooting your router before accessing the webui. See if after the reboot it properly detects DOwnload Master as being installed.
  15. bobloblaw
    Nov 7, 2012
    19
    Thanks, I will try this out later
  16. bobloblaw
    Nov 7, 2012
    19
    Hi Merlin, no luck on this yet.
    I copied the edited S50downloadmaster file, rebooted and it is still asking me to install download master. Every time it gets reinstalled, the amule service starts back up.
    edit*
    to be more precise. When I reboot the modem after copying the edited file, I can't access download master
    I can fix this by uninstalling and reinstalling it but then we have the same problem again.
  17. bobloblaw
    Nov 7, 2012
    19
    Just a quick update on this, I flashed the new stock 3.0.0.4.260 firmware and now I am not having the issue with amule.
    I will have to keep an eye on it for a while but for the moment it seems to be fixed
  18. bobloblaw
    Nov 7, 2012
    19
    This issue just reoccurred worse than before. 40 GB uploaded in one day.
    Is there a way to remove amule completely?
Share This Page
