Enabling WireGuard Client
jkshowers
Ok, so I am pulling my hair out.
No matter what I do, I cannot get the wireguard client to go from stopped to enabled.
The director shows it is enabled
I have clicked apply a million times.
the client tab shows that Yes enable is highlighted but says stopped next to it.
I would really appreciate some help! What am I doing wrong?
Bad config file, probably because service uses OpenVPN format as far as I can tell. Import the config file using the OpenVPN button instead.
On stock Asus Firmware The file works fine. I’ve tried multiple files to have the same problem.
