are you measuring in micro seconds? It seems like the best latency you got is about the same as i get. I've seen LAN pings of 0.1 ms but have never managed to achieve it.
From their website: Note that fping must be installed setuid root. It seems that older versions of fping report round trip times in 0.1 milliseconds instead of 1 milliseconds as advertised ... SmokePing tries to figure this out. It tells you when it starts ... let me know if it gets it wrong.are you measuring in micro seconds? It seems like the best latency you got is about the same as i get. I've seen LAN pings of 0.1 ms but have never managed to achieve it.
For ethernet LAN ping should be 300 microseconds or lower. If you're getting around 500 microseconds or higher it is likely something is being slow in your network. Some dedicated NICs integrated into the board such as marvell however may have a response time of around 500 microseconds.
Welcome To SNBForums
