goncalossilva
I've been having trouble rebooting my RT-AC68U running 378.50 unless I manually toggle the power button.
Most of the times, when I reboot the router (via the Reboot option in the web interface or my weekly reboot cron job), it appears to come back normally but then clients can't connect on either 2.4GHz and 5GHz. I also tried connecting via ethernet when in this state but the computer doesn't get an IP address. If I cycle it using the button, it starts working properly.
This problem isn't new -- I had it at least on 376.49 and 376.48, if not earlier versions. I have cleaned nvram a few times now but to no avail. I can't find anything on dmesg or syslog which might indicate what the issue is.
Any ideas? Thanks!
Any ideas? Thanks!
