Long story short, I was tired and totally missed the fact that I downloaded merlin's firmware for an AX68U router and not an AX86U router. Once it was flashed, I couldn't access the mesh or reset the device! I thought I was stuck and bricked the mesh router. Here's how I fixed it as I'm sure someone else is bound to do the same thing / be in the same situation in the future.
- First thing first was to get the router back onto my mesh network as I couldn't log into it or reset it. To do that, you need to ensure your ethernet backhaul connection is on port #1 (my usual backhaul connection is on the 2.5G port, but the AX68U firmware doesn't recognize that port).
- Once you have the router recognized in your mesh network, it'll show "offline" in your nodes like this (attic):
- Click on the device and obtain the IP address
- Navigate to Administration -> System -> Service and ensure Enable SSH is "LAN Only" and make note of your SSH Port (default is 22, but it's a good idea to change it). Save / reboot
- Open up WinSCP and log into your mesh router (the broken one) over the SCP protocol, should look like this:
- Enter in your router username and password (it's not the default admin / admin, but your password to get into your main router - 192.168.50.1)
- Copy the correct firmware file (e.g. RT-AX86U_3004_388.6_2_pureubi.w) over to the /tmp/home/root/ folder. Can drag / drop, should look like this:
- Open putty (ctrl+p in WinSCP), retype the main router password you used to log into WinSCP with
- Copy the command "hnd-write RT-AX86U_3004_388.6_2_pureubi.w" as shown below and hit enter. Obviously change the filename in the command if you're flashing a newer / different firmware version
- Once it's completed, type "reboot" and click enter (this will end your putty / winscp connections)
- Once rebooted, go plug that ethernet backhaul back into the 2.5g port
- Click "Reboot" at the top of your 192.168.50.1 main router page to reboot all devices in the network
- Pay extra attention next time you do a firmware update!
